Hi Folks,
I'm the second owner of a 2007 Hunter 410 -- The Xantrex Freedom Marine 20 charger/inverter is failing on us -- The high-temperarture warning goes off all the time when it's doing heavy charging. I've isolated the issue to the circuit that controls the cooling fan. Something there has failed (the fan itself is fine).
It's out of warranty with Xantrex, and so I'm trying to figure-out if I can get it repaired at a reasonable cost vs. whether it's a better idea to replace the whole unit. The Freedom Marine 20 is connected to a nice control panel at the nav station, so picking a different brand would need to deal that idea in as well.
Let me know if you have any advice for me?
Thanks,
Eric
Thanks,
Eric
