I recently purchased a 2005 Hunter 33. The Owner is deceased and minimal info on boat other than owners manual. Boat is slipped at Kerr Lake in NC. We will use the boat during the winter season, but I was going to winterize engine as needed. Also was going to drain/winterize fresh and waste water holding tanks. The boat has sea cock/thru hull valves for the galley and vanity, so assumed it exited the boat in to the water. however, when draining the fresh water tank, the waste water tank gauge increased the same amount. Is it possible that the fresh water system exits to the holding tank? Problematic as the specs stated the fresh water tank larger than the waste water tank.
Also wondering if necessary ( and how) to winterize air cond system. water heater in this region ( Kerr Lake, NC).
Thank you in advance.
