Companionway Stair Upgrade
Gunni
Mar 16, 2010
5,937
Here is nice little safety (and cosmetic) upgrade I just completed on my companionway stairs. The original stairs were very nice, but they didn't provide enough traction for what can be a very slippery surface when rain or sea spray enters the companionway. After experiencing too many slip and fall incidents it was time for some upgrades.
Here are the OEM stairs, the black lines are rubber traction strips, the rest is finished marine teak ply - tres joli! ...inadequate grip.
Pull out the rubber traction strips, clean adhesive, fill with plastic wood, mask and sand.
Using tacky shelf paper cut a pattern and trace to Lewmar TreadMaster non-skid. Cut with heavy shears, sand (120) and shape edges. Dry-fit to get it just right. Mask the adjacent stair tread in preparation for application of contact cement.
TreadMaster flipped and laid out on cardboard, ready for contact cement. Note each tread is slightly different in dimension and numbered by stair location. 2 coat with Weldwood contact cement, same with sanded stairs (wipe with acetone).
Positioned and pressed. Finished treads - super grip, wet or dry!
The material is TreadMaster Diamond in teak color. A combination of ground cork, rubber and polymer it is typically specified for non-skid deck installs and comes in a number of different colors. A 48"x36" sheet would do 6 of these stairs with material left over.
Likes: kloudie1
Jul 8, 2005
522
Jeanneau 389 Grosse Pointe Farms, MI
Nice handiwork! I have slipped on the stairs as well and always have wondered how to make it better.
Likes: Tide88
Gunni
Mar 16, 2010
5,937
I knew I had to do something but dreaded the job, not wanting to do a half-baked effort. In the end it turned out to be a pretty easy job, just some careful patterning, and prep. The TreadMaster cuts easily with heavy scissors.
May 24, 2004
7,228
CC 30 South Florida
The problem with slipping might be worn boat shoes. Not saying the steps might not be slippery, just saying that if you slip on the steps you are likely to slip up on deck.
MitchM
Jan 20, 2005
1,031
nice job ! and i do love and envy those lovely wooden handrails you have. (if they ever go missing you can suspect me. )
Gunni
Mar 16, 2010
5,937
Ha! I keep looking at them trying to figure out how to get them off for the inevitable refinishing. Suntan lotion is like paint stripper!
