So...after completing the exhaust overhaul, some wiring upgrades and yearly maintenance it was time to crank up the old motor! Well, the main battery wasn't fully charged, but I had a lawn mower battery with me as a back up. Unfortunately, I had a massive brain fart and attached the battery backwards and attempted to crank. Immediately, smoke started coming from below, I turned off the battery switch and did a quick assessment. I found that one of the terminals on the battery was almost fully melted. Smoke was also coming from around the starter, solenoid, and generator. I did notice some melted insulation from the big wire that connects the generator to the solenoid. After the smoke cleared, I disconnected the batteries and made sure nothing was smoldering, I went home before causing anymore harm.
When I return to the boat, what do I do first? What do I need to check and in what order, before trying to start the motor?
The motor is a Universal M-12.
