NO, NO....no sawzall on the post socket. The base of the post is set in about 3.25-4 inches- they just slopped FG around it to hold it when they made it. I chiseled out the rotten wood. Note that the stern-side bottom corner may be slanted in slightly. I made the post to fit - a planer is really handy - and tipped it into the socket filled with just some thickened resin, hammering it up to a tight fit on the headliner. Note too that the port bulkhead fits into a rabbet on the leading edge. You might have to trim the FG around the slot a little.
The sawzall work is just to cut the bulkhead off the hull. You can slide the blade in at the top and just easily slice the tabbing by following the curve. Be careful taking the bulkheads out- they can be used for a pattern for tracing. (There are 6 sheets of 4x8 plywood in a 25! - rebuild the galley, bulkheads, and head space, and you will see!) How long all this takes depends on what tools you have, and how much care you take. I did epoxy on the bottom to seal the grain, then 8 coats of varnish - about a month total. I have a lot of tools though. I hope you have a bunny suit, face shield , respirator (a can filter one, not those useless fiber things, and ear muffs.
AND, while you are at it I would check the wood panel on the SB transom. Those are notorious for rotting out. Put a 125lb motor on there and you get oilcanning and hull damage. Check the king plank too. I had to replace both twice, on two 25s . THAT is a NASTY job. Let me know.......have pictures - mine is bomber now, but it's a J.O.B. --16 hours of grinding.
