Has anyone attached the original Z-Spar aluminum mast step (with internal halyards and sheaves) to a hinged mast plate? I don't want to replace the mast foot as I like how it functions, but stepping the mast is difficult ( I have to do it in the water) with the aluminum foot only having one pin and side sway is starting to bend the foot. I would like to attach it to a hinged mast plate with two pins and less risk of side sway while stepping. The front of the original mast foot does not have any way to keep it attached to the original mast plate - there would be two pivot points. Any suggestions?
