Hello, My mastbase on my 83 Oday 28 has had a leak since I have had the boat (5 years) and its getting a little worse, hasn't been a bad leak but in an attempt to fix this issue I installed a new Mast boot last year and ever so carefully installed it so that there was no possible way for water to enter from this area. Well there is still a leak and I now think it is seeping in from around the mast base itself. I applied a bead of sealant around the edges of the collar (as seen in pics) but still no help. I was considering taping off the area very neatly and spraying some coats of that black rubber spray around the area to see if that helps, any suggestions would be appreciated..
Here is what I believe I hav-
Isomat NG-31 Mast
Isomat NG-31 White Mast Boot (old and was replaced)
Isomat NG28-10: Deck Collar – 5 Bail Type
Isomat NG-31 Mast
