Found a leak on my 13 year old aluminum tank. For those that may be wondering, it will come out the starboard side access panel after removing the water heater. The retaining dam for the tank holds water (and fuel) and has no weep hole. I also found that the shelf which holds the water heater is not water (fuel) tight, and has no weep holes. After removing the tank I still had weeping fuel and had to cut drain holes to get the fuel out from under the shelf. After several washings, I am hoping to be rid of the fuel smell. Will reinstall tank after Matt goes away.
