You will be drilling two holes: One will be for the through bolt, and the other will be for core removal. The bolt hole will be your pilot hole for the core hole. Do not penetrate the liner with the core hole. Tape the bolt hole on the liner and fill the core hole with epoxy. I like West System Six in the self mixing tube. Level and when set apply the butyl tape on the footprint of the track and bolt it down. There are any number of ways to dress up the bolt ends; acorn nuts, nut covers etc.
Hello Gunni:
Thanks for the good info. But could you provide some more description to be sure I understand and so I might adapt for "variations on the theme".
- The bolts will be 5/16" diameter so I presume that the core hole will be say 1/2" in diameter? Would 5/8" be better? (I am using a 1 1/4" T-track.) Then after the epoxy injected into the core hole sets, I would re-drill the 5/16" bolt hole through the epoxy "plug"?
- I will need to drill an exploratory hole, but I am pretty certain that my boat has a gap between the deck's lower FRP layer and the liner. So after the bolt hole is drilled all the way through, I will use a 1" bit from underneath to widen the bolt hole in the liner so I can put on the tape to prevent the core hole epoxy from oozing out the deck's bottom FRP layer. And so I can put on the fender washers and the nuts. So in my case, the depth of the core hole will be only to, but not through the deck's bottom FRP layer.
- Another thought. Instead of epoxy into a larger diameter (than the bolt) core hole, would flooding just the bolt hole (first drilled only to the depth of bottom FRP layer) with penetrating epoxy provide enough protection from future water damage to the core in the event the butyl tape's seal becomes compromised at some point? As I described in my opening post, I am pretty sure that my deck's core is plywood rather than balsa. (This because plywood is what I discovered when I removed the top skin of my wet core cockpit sole. The wood itself was still hard, not rotted, and was still tenaciously adhered to the top and bottom FRP layers ... it took me several hours with a sharp wood chisel and then a power sander to get all the plywood out. The water ingress through the pedestal and guardrail bolt holes however had caused the glue bonds between the plywood layers itself to separate.) Back to the T-track mounting project, since my deck's core likely is plywood, seems I might not need to be as concerned about the core material compressing/deforming around the bolts, as I would if the core was balsa? So is an epoxy core hole as necessary? Obviously I am looking to save a step or two if possible. Your thoughts?
Again thanks.
