Excessive zinc relacement
Apr 30, 2016
48
Hunter 376 Port of Los Angeles
Hi all,
I bought a 1999 Hunter 376 sailboat in February 2016. I'm a new boater. My Marina is in the Los Angeles Port, CA. Lots of tankers, container ships, Tugs going by marina (I assume a lot of electrical current in the water).
I have a diving service cleaning my Hull every month and replacing zinc anodes. Appears I have 2 zincs on prop shaft, 1 zinc on Flex O Fold prop, 1 zinc on Rudder plate (small).
It appears they replace one of the shaft zincs every month and sometimes both at the same time. They replace the prop Flex O Fold zinc every 2 months. They replace the zinc rudder plate every 2 months. I pay $109-$124 for hull cleaning and zinc replacement. Too much money.
This is my situation:.
1) I have an galvanize isolator behind navigational switch board.
2) I have a Inverter and no Generator.
3) I am always hooked up to shore power.
4) I have a live aboarder birthed next too me.
5) I live aboard boat while I work in Southern, Ca (I am living on boat 80% of time).
6) I have not yet cruised yet, but I plan on it.
Questions:
1) Should I disconnect shore power when I'm not on or using the boat?
2) Hire a ABYC certified boat electrician to troubleshoot issue?
3) Shut off inverter when hooked up to shore power?
4) Or just move to another marina? LOL
5) My last question is with attached photo. What are these wires in my rear bilge? It appears when I unscrew cap with no wires water comes in bilge. It appears there is an option to replace cap with no wires with cap (with wires). Notice cap (on right side) laying next to cap (with no wires). Notice holder on left where cap with wires held in place when not used. Cap with wires also has a impeller or propeller that must be propelled by water when screwed in.
Thanks,
FriscoRon
7,379
Alden 50 Sarasota, Florida
That is a knot meter. The cap is used to close the thruhull when it is removed for cleaning (as it is now).
Before getting too wrapped up in the myriad of possible reasons for zinc loss, the first question is whether you can tell if the zincs are being eaten away that quickly or do you have an over-zealous hull cleaner prone to exaggeration. Have you seen the zincs he removed from your boat?
Apr 30, 2016
48
Hi Don,
Attached is two prop zincs replaced. One in May and one in September. They forget to leave the other zincs on my boat swim out for the other months. I believe these are pretty much deteriorated.
Thanks for that info of the boat knot meter. I guess I don't need that until I'm cruising. I'll read my manual on that.
Ron
2,117
As a 80% live aboard, you probably encounter lots of owners in the marina. Ask them about their anode depletion experiences and solutions. That should help you zero in on whether you've got "hot" location issue, or maybe also have some fault with your boat. Either case, a pro can assist zeroing in. Probably a better alternative than moving marinas only to find the same issue elsewhere.
Since you spend lots of time on your boat almost every day, unplugging from shore power say during the day, but connecting again every night, might slow the replacement frequency down a bit, but it's not the solution.
A stop-gap option, particularly since you don't leave the berth much is to hang a "fish" zinc.
On my boat, I have a shaft zinc, but I also have a "fish" zinc hanging over the side. It does sacrifice, so that's evidence it is helping. Between the two, the shaft zinc depletion rate is definitely reduced. If I didn't ever sail, I might even forgo maintaining a shaft zinc. But on the other hand, props are expensive, so its not worth saving a few zinc $'s in the exchange.
To ensure a good contact between the fish zinc and the shaft, I installed a shaft brush like this: http://shop.sailboatowners.com/prod.php?5673 to which the hanging fish is connected to. And for good measure, I also have run a "pig tail" from the fish lead to the engine block.
As to the fish zinc, the sailboat marketed ones are expensive. So I have a supply of these $3.60 zincs which are marketed to crab/lobster fishermen to protect their pots: https://rotometals.com/1-5-lb-tie-on-crab-pot-zinc-anodes/. To use these you will have to design your own connection between the crab zinc and the wire leading to the shaft brush and engine block. But if you design right, its a simple matter of pulling up the fish zinc every few weeks and if it is pitted/sacrificed, fit on a new one.
48
Thanks Rardi,
I was told I'm in a hot spot marina. I'm little confused on the rigging of this fish zinc and shaft brush. Is there anyway you can provide me with a diagram or photo of this rigging.
Ron
7,379
I once did what Randi suggested and found it did work as a temp fix.
Simply run an unbroken wire connected directly to the shaft into the water with a zinc attached. As you don't move, there is no concern for forgetting to disconnect it from the shaft. Being unbroken is important to minimize any resistance along the path.
JamesG161
Feb 14, 2014
7,754
Hunter 430 Waveland, MS
You should move immediately or have them find the "hot spot" culprit. I had to find the "bad actor" in my marina.
Once he fixed his newly wired boat. I change my zincs once a year.
Jim...
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
I have been told by boat owners in virtually every one of the dozens of marinas I have worked in over the last 22 years that their marina is "hot." Usually this is not the case and is the result of the boat owner simply being in denial about the state of his own electrical system. Rapid anode depletion is almost always the result of an electrical issue aboard the boat in question. Cudos to you for acknowledging that possibility.
The anode loss you appear to be experiencing is extreme. I would recommend you do two things:
1.- Have a marine electrician go through your electrical system to suss out the problem. If he can't find one aboard, have him check the shorepower system and for any stray current in the water. If there is an issue with either of these last two items, request that the marina alleviate the issue.
2.- Require the dive service to leave all anode remnants on the dock each and every time they replace one. It is a little suspicious that they have "forgotten" to leave the majority of the anodes they are replacing, especially since they are replacing them so frequently. They should be concerned with providing you with evidence of the problem. If they seem to be unable to do this, find another dive service.
BTW- the rudderplate anode is mounted on your strut, not on your rudder.
2,117
Thanks Rardi,
Ron
Ron:
Being at my boat yesterday, I took the attached picture of how I have connected the hanging zinc to the SS wire (salvaged from an old lifeline!) that leads up to my boat. The same clamps and wire have been in the water now for 3-4 years.
Inside my cockpit, I have installed a connector plug, so when I go out sailing, the hanging zinc wire can be easily detached from the further "interior" wiring for the run to my engine block and shaft brush. I tie the hanging zinc to a small line on the dock so I can quickly re-attach when I return.
As to more details, although I am comfortable that my hanging zinc bonded to both the engine block and the shaft brush assists with my protection*, I am not expert enough to confidently commit to any specific details.
Lots of info is available on the net: Search for Hanging Zinc Anode. And Marine Shaft Brush.
As mentioned my opening post. A hanging anode is something that is easily added to assist, but not solve your problem. So certainly follow-up on the other suggestions.
* For instance, just last week, I engaged a diving service to clean/inspect my bottom and check (and replace if needed) the shaft zinc. At the last service, about 4 months ago, the diver reported that the already 6 month in-service shaft zinc was still fine until the next service. But at last week's cleaning, the zinc was gone. Fallen off at some point. So I had the comfort knowing that the hanging zinc at some point assisted assuming the protection duty. Also attached is a picture of a new anode vs one that had been in the water for I think about 6 months. The difference shows the hanging zincs are sacrificing. At the time of the photo, I was using Aluminum Alloy anodes. I have since gone back to zinc.
1,140
Fast is right. Stop guessing and listening to rumor. Measure your hull potential and in less than 10 minutes you will find the answer
Charles
Apr 30, 2016
48
Thanks Rardi,
I will check this rigging out. Anything to stop my excessive eroding zincs until I troubleshoot and resolve the real issue.
Ron
Jan 30, 2012
1,140
Yes any VOM will do but your article discusses AC and AC will have nearly nothing to do with zinc wasting.
Get 20 feet of no. 16 wire and solder a pencil zinc to the end. The VOM probe goes to the shaft, pencil zinc wire to VOM common, with pencil zinc in the water.
Test for DC volts with VOM on low scale. Same test for any other under water metal with zinc.
I will send you a sketch when I get off boat
Charles
24
Beneteau Oceanis 45 Palm Beach
Check the galvanic isolator. It should be installed where the shore power enters the boat.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
It was suggested that your diver may be replacing too often. While it appears you may have a problem, I would not personally replace a zinc in as good a condition as your picture shows. Fstbttms can probably advise more on this. Chief
Feb 26, 2011
1,440
The pic does not adequately show the state of depletion of the anodes, IMHO. Tough to make a call based on that.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
My zincs looked pretty good on this haul out until they got hit with a pressure washer. I could see that were clearly wasted. I'm just curious why one would switch back to Zinc from aluminum? I too need to spend a couple minutes checking my Galvanic Isolator.
Ken
Nov 26, 2012
2,315
Ken: you need a sacrificial metal which means the least noble. This means the softest metal will corrode first. Zinc is usually used and seldom aluminum. You might use aluminum if you know you have NO aluminum such as a prop in the water.
Chief
MitchM
Jan 20, 2005
1,031
check whether anyone close by in your marina has a Carver which was recently re wired by an amateur non - ABYC certified electrician.
