After many years of owning small power boats, I wanted something different. So, bought a MacGregor 25 with trailer and an electric start merc outboard. The manual states never to run this engine without being hooked up to a battery, else the charging circuit will be damaged. The former owner ran wires out of a vent cover on the stern that have crimp connectors on them. The motor has corresponding connectors. There are bolts to connect the hot to hot and ground to ground. There is no way to insulate either wire other than to wrap them with electrical tape. Not a great way to hook up the electric! I would like to transport the boat without the motor attached, then hook it up when I'm at the ramp. My question is, is there some type of insulated plug and receptacle that is appropriate for this use? The wires look to be at least 12 gauge, possibly 10. Merc recommends a battery of 465 amps and 350 cold cranking amps for this engine, so the connector will need to be stout. Any recommends will be greatly appreciated. Thanks for any and all suggestions, Tom
