refurbishing aluminum water tanks
eianm
Jul 7, 2010
523
Hunter 42 Sydney
I have embarked on a project to refurb. my 2 x aluminum water tanks on my H42. I am not as brave as Dean (TTAC)- I have done a lot of research and will post a detailed summary of this project over coming weeks. It will include before and after scientific water tests!
I hope this could be a major break through in this area!
7,601
Alden 50 Sarasota, Florida
Curious what research you refer to. And what water test(s) bear on the issue of pin hole corrosion?
eianm
Jul 7, 2010
523
Hunter 42 Sydney
I have been looking for a coating I could apply that was 100% safe/ non leech-able - intended for potable water- I have finally found something. As I am sure you will be aware, human aluminium intake is dangerous and thought to be a carcinogen.
So I will have water tested prior to refurb. and after refurb. to see EXACTLY what is in my water. I do use an activated carbon filter for a drinking water spout- I will also test water from that. The other point of research was how to effectively fill any pin holes, prior to surface coating.
7,601
I think you are worried about the wrong thing.
Aluminum is neither effectively removed by carbon filtration nor is it typically present in toxic concentration. It will precipitate at normal pH as a white gelatinous substance alum hydroxide.
Studies linking Al in drinking water to human health issues have been inconclusive. The bigger problem is the potential for leaking thereby promoting the growth of molds in volume d spaces around the tank(s) which may be a bigger impact on health.
Dec 25, 2000
5,953
Better than replacing the tank, eh? Looking forward to your owner mods article. Our 1991 tanks are still okay, but at some point...
eianm
Jul 7, 2010
523
Hunter 42 Sydney
here is a picture of the cover plates i made out of polycarbonate that I haven't been able to get Maine sail to add into the owners mods article- i probably went a bit OTT with the bolt spacing's at 30mm, but it wont leak!View attachment 129224
Nov 21, 2007
673
O-K... I just came across that write up earlier today, and it's laying in a pile on the end of my desk...
Cue the Twilight Zone theme...
:oops:
