2016 OC 45 Air cond. Sea Strainer
May 10, 2007
42
Beneteau 45 Annapolis
Does anyone know who makes the air conditioner sea strainer for the 2016 Oceanis 45? I tore the gasket when I opened the strainer (it was stuck to the metal and tore as soon as I turned it.) The dealer says they can't get the gasket, only the whole strainer!
It's a Sherwood on our 2014 37. The plastic on part of ours was split and the dealer said the same thing about it only being replaceable as a unit. Ours was still under warranty at the time so not as big a deal.
Jun 15, 2012
717
BAVARIA C57 Greenport, NY
I made a homemade gasket that worked perfectly. Get a small sheet of rubber gasket material (red/black color) available at the plumbing department at Home Depot. Using the clear plastic cover as a guide, draw a line on the material and cut with a scissor.
May 10, 2007
42
Thanks for the replies. The 2016s have a totally different stainer. It's all metal - no clear sections. I was able to find an o-ring at the hardware store that fit. The original gasket was flat, but the o-ring seems to work.
The gasket that came with the boat was totally dry rotted, that's why it fell apart. Odd for a new boat.
May 27, 2015
35
Beneteau Oceanis 41 Havre de Grace MD
Mine is the same as yours. The sea cock and strainer may have sat on a shelf at the factory for years before it was installed.
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
OMG!!! Don't go to the orange box! Lowe's is waayyy better
