threaded backing stripped
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
3 out of 4 backing plate holes on one of my opening deck windows are stripped. There's nothing for the 2 window hinges to hold onto. There's no access to the plates. What's the proper way to restore grip for the machine screws (bolts)? Would helicoils work? Should I just dab some JB Weld on the tips and push the bolts back in? Even if I ever have to replace the window, I would only need the disconnect the other half of the hinge.
Jul 7, 2004
8,542
That crossed my mind. I'd have to enlarge the hinge holes and re- countersink. Might be tough with stainless.
Dec 28, 2014
61
Hunter 280 Mandeville, LA
Thought the embedded backing plates were alum but at any rate, I would gently try a self tapping SS screw with just a tad more cross sectional thread diameter and see if it grabs.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
I believe he was saying the port frames are SS and needs to enlarge the hole and c'sink. SS isn't too bad to work with. Good quality bits and c'sink helps plus using oil and use a slow rpm. If it were me, I would go with helicoils. They really should have been used at the factory imo. Where I work, no threaded aluminum is ever used without helicoils.
Jul 7, 2004
8,542
I haven't tackled it yet but I am leaning towards helicoils. I wouldn't have to enlarge the hinge holes to accommodate a larger machine screw.
Mar 26, 2011
4,063
Corsair F-24 MK I Deale, MD
You don't need to remove the hinges to replace the lens. You can either take the whole hatch home or do it in-place.
Jul 7, 2004
8,542
I'm not replacing a lens. I'm trying to secure the window back to the deck. The plate is stripped out. We discovered it when we opened the window to clean.
Feb 10, 2004
4,255
Hunter 40.5 Warwick, RI
I have successfully used helicoils in aluminum pieces on a pedestal. They would be my first choice.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
In order to make Heli-coils work, you would need to bore the holes out bigger. The ports should have been secured to aluminum embedded in the fiberglass. It's pretty easy to just re-drill and tap to the next larger size. If they ever failed again you would still be able to install the Heli-Coils, but I doubt you will need it. There should be little stress on the fasteners. Then when you put it back together be sure to put some anti-seize on the fasteners. Stainless in aluminum seizes easily. Be sure to seal it well. I suspect the root cause of the problem was moisture seeping in and causing corrosion.
Ken
