Electric conversion for Hunter sailboat
Jan 26, 2015
5
Hunter 35.5 Lake Lanier
Has anyone tried an electric motor conversion for a Hunter sailboat? I have a Legend 35.5 with a blown engine and am thinking of replacing the diesel with and electric motor conversion; the boat is on a large lake in Georgia and the motor is only used to get in and out of the marina, usually less than fifteen minutes. Any suggestions pro or con would be appreciated--if you have done the conversion I would be very interested in your input.
Thank you in advance for your suggestions.
Jun 6, 2006
6,990
Is it possible? yes. In your case it might even be practical. however, the calculation for the battery bank needed for a 1 HP motor go like this;
1 HP = 746 watts. At 12 volts that is (P/V=I) 746/12 = 62 amps. If you run the motor twice getting in and out of the marina for 15 minutes (0.5 hours) that is 62*0.5= 31 Amp-hours (Ah).
The unfortunate part is you will probably need something like 10+ HP to account for wind, current etc. so what you need is 310 Ah. and you don't want to discharge your bank below 50% so 620 Ah just to get in and out of port. That gives you some reserve (take the bank below 50%) but I'd not plan on using that except an emergency.
If you plan to sail to another location and us the motor for 15 minutes getting in and out of that port then return to you home port (all without charging the bank) you end up with a 1240 Ah bank........
So you need to determine what HP you need and consider what the next owner is going to think about only having a 0.5 hour motor.....
good luck
Likes: kloudie1
Johnb
Hunter 37-cutter Richmond CA
Oct 30, 2011
542
klidescope 30t norfolk
On a lake a fresh water environment I'd be curious at possible gas conversion I realise it's a back ward's conversion but a dependable 12 hp 2 cylinder Honda v twin from northern tool cost like $600 on sale it's like 400 lbs lighter than the yanmar electric start the only challenge would be adapting shaft to existing transmission but possible a good machine shop could make an adapter plate and shaft coupling to do then custom motor mounts reconfige wiring and done small altnator so no recharging on hook
Oct 28, 2013
678
Hunter 20 Lake Monroe
That is an interesting thought. The Honda would be air cooled so you would have to cap the water inlets and plumb in air ducts for cooling air and then a way to get the heated air out of the engine compartment.
A good outboard would be a lot less hassle though.
Sam
Oct 30, 2011
542
Flynhigh4u I just added a 4" duct and blower fan to do that with my yanmar diesel to pull some of that heat out the dog house in summer so that part possible the exhaust would be the next challange
Oct 28, 2013
678
Oh it is defiantly doable, would just require some patience and thought. You would still have the non marine carb to deal with. Not sure how well the ins companies would like that.
Sam
Oct 28, 2013
678
Interesting site. The price is certainly attractive till you factor in the battery cost. I would think for someone who sails a small inland lake with wind that can be counted on more often than not this would be a viable and "green" alternative. Not sure how well it would work for "cruisers" but I would be interested in hearing from an actual user.
Sam
Jun 11, 2011
1,243
Hunter 41 Lewes
Hunter made a hybrid electric boat. I think it was a 32'. I think Elco makes electric boat propulsion systems. They don't run them at 12V.
Nov 8, 2010
11,386
Sam
Correct, The OP posted this "the boat is on a large lake in Georgia and the motor is only used to get in and out of the marina, usually less than fifteen minutes." and that is the perfect use case.
It looks like a well engineered system for a particular type of user. I'm sure it would come in less, but its not designed to be an el-cheepo way to replace your dead diesel.
Dec 14, 2009
37
Hunter 29.5 Buffalo
good luck
If you actually do an electric conversion you would not use a 12v motor.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Hunter did have a electric H-36 and did see it at the Miami boat show a few years ago and
was impressive for sure with solar panels on the bimini and also a I think a Gen backup option.
Nick
