Hey All U Get, I think you're on the right track. These are LED lights, so resistive measurements probably won't work. I think the LEDs are arranged to drop 12v in each direction (one way for white, one way for multi), but only if provided with enough current (25W?, ~2A). Instead, when you open the circuit they will hold a charge on the wires (the wires will charge up like capacitors). You might buy (or borrow) a cheap ($36) DC clamp meter. With regard to our forum rules... This is a link to a product for sale to perhaps solve a problem for a fellow member and not an advertisement or endorsement of a product for sale. In fact, I would recommend buying something much better - lol! (
https://www.amazon.com/Uni-T-UT210E...=1469573680&sr=8-1&keywords=dc+clamp+on+meter) . Leave it all connected, energize the light, and then look for about 2A (or so) on a (suitably suspect) black wire. Actually, measure the red wire first, then look for around that same current on one of the black wires.
EDIT:
1. Ignore the polarity of the meter readings (you may not be holding the meter the same way on different measurements).
2. LEDs are non-linear devices, so resistance AND voltage measurements won't be like measuring through a purely resistive bulb.
Hope this helps.
EDIT:
3. Ok, the DC clamp meters use a hall-effect sensor. Problem with these meters is zero drift, so you have to first clamp around a wire with no current flow, then zero the meter. After that you should be good-to-go. Good luck.
