Don, Bill
Thanks for the quick replies. I've replaced the thermostats, the seals and have the circulating fan. I still have to defrost more frequently than I like and temperature control and redundancy for cruising are other objectives. I will search the upgrades section. Thanks.
I don't see adding a seperate unit for the refrigerator instead of the spill over arrangement doing anything to for the frost problem other than that you don't introduce moisture to the freezer plates as often and the refrigerator plates would be less cold so frost up less (maybe).
I'm happy with my system and the only things I've done is replace the condenser fan with a quiet one (can't hear it run when sitting over it now) and I put a small battery recir fan in the frig side to make it more even. But those don't do anything for the frost and I defrost every 3-4 weeks (I completely do it once in a while and sometimes just do at the fan and hole for the spillover system).
I have a electronic thermo for the spill over fan but haven't put it in yet. I also have been considering putting a sheet of plastic or Teflon on the freezer evaporator plate a cross from the spill over holes to replace the ice build up there.
BTW - the last 3 years I've turned my system on in April and not turned it off till Oct.
