Sandbags
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
The PO told me that he was advised to install two sandbags under the forward berths of my 96 H26 to counteract the weight of the motor. Has anyone else done this?
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
Not for the motor's weight, but I put 3 in mine to offset the 4 GC batteries in the port quarter berth. She sits right on her lines now!
I intend to replace them soon with something more useful - a flexible water tank.
Jun 1, 2004
8,270
Adding or relocating ballast can help a boat's performance. Fore and aft trim is a consideration with any boat. Take a look at how your boat sits in the water by circling around it while anchored. If it looks like it is squatting a bit... adding some ballast under the vee berth may help trim it up..
Tsam
Jun 28, 2011
30
S2 6.8 Long Lake, MN
What about the weight of crew in cockpit? Could easily be over 300 lbs.
Sep 2, 2011
1,041
If the motor itself makes that much difference, it must be an oversized whopper. Sandbags? A Bow Bunny would make more sense.
Nah, ya need about 160# to balance the motor. Don't wanna see that Bow Bunny
Jun 2, 2004
649
Hunter 23.5 Calgary, Canada
I've had my 1995 H23.5 since 2002. I noticed that it sat listing to starboard because the outboard, fuel tank, battery and portapottie are all on that side with nothing on the port side. The sink water bag is empry - I've never used it. I balanced it with an arrangement of bags of kitty litter totalling 150 lbs. I've never thought to consider the fore-aft balance. The bottom paint that came on the boat is level with the water but who's to say it's right!
Jun 1, 2004
8,270
Yep... that can affect trim also... but crew are "movable" ballast. When sailing downwind in light air, moving some of the crew forward can help lift the rear of the boat to reduce drag.
Fred
Sep 27, 2008
517
Another concern I have with this additional weight is the stress that it puts on the hull, particularly when on the trailer.
Fred
Sep 27, 2008
517
Dave... Are you saying you would not recommend the additional weight if the boat is being trailered?
-na -NA Anywhere USA
I would not leave a lot of additional weight in the bow or the very rear if that area extends the bunk boards on the trailer. Maybe 150 pounds might be ok but the addl. if too much may cause the hull to dimple a little just past the bunk boards. Not sure but that is the first thing comes to mind. I could very well be wrong but who knows.
