H31 owners treat yourselves to one of these
Feb 6, 2013
437
Hunter 31 Deale, MD
I had to pull the engine control panel and found that is was in really bad condition. One of the PO's had removed it previously and broken off all four corners, then fabricated an aluminium frame to hold it in place and sealed it with 4200.
I bought a new OEM panel for $28 and a new rubber OEM gasket for $7 from the local Yanmar dealer
The PO could have saved himself a lot of trouble.
Likes: Ken13559
pateco
Aug 12, 2014
2,207
Did that as well. Original was cracked. Money well spent.
May 24, 2004
7,235
CC 30 South Florida
Yes without the instruments those panels are inexpensive, did not know there was a rubber gasket available.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
I have done that as well. It is indeed money well spent. Also put in a new tach because the old one was shot...that bit the wallet hard.
Aug 2, 2014
105
Hunter H31 VISA
I took you advice and bought one as well. What did you do for the engine shut off knob to install the new panel? Did you have to disconnect the cable from the engine and pull it all the way back to the panel? I tried twisting the knob off but it wasn't moving and I didn't want to force it. Thank you.
HMT2
Mar 20, 2014
900
DF, Roger that. There is a little block that moves a little at the kill lever on the engine. (see photo) Release the screw and pull the cable out, then run it back through, its not terribly difficult just be careful not to bend or break it.
pateco
Aug 12, 2014
2,207
DF, Roger that. There is a little block that moves a little at the kill lever on the engine. (see photo) Release the screw and pull the cable out, then run it back through, its not terribly difficult just be careful not to bend or break it.View attachment 125661
My panel wasn't that bad, with only one corner cracked off.
However, my stop cable was totally seized, which was the main cause for the crack in the original panel. It took multiple soakings with PB Blaster while flexing and pulling the cable to break it free. So, if yours is not seized, take the opportunity to clean and lube up this cable. Also take this opportunity to flush out the cable tubing with lubricating solvent. IMPORTANT Make sure to put the other end into a bucket or cup so as not to spray lubricant all over the inside of engine bay.(ask me how I know. LOL). I used Ultra-Lube to re-lubricate the tube and cable, and it has been working perfectly for over a year in the new panel.
Finished
pateco
Aug 12, 2014
2,207
Also, while I had the cable out, I cleaned up the frayed end by trimming a little off, and then tinned with a little solder to keep it from fraying again. IMPORTANT The cable has to be free of lubricant for the solder to stick. so do this before re-lubing. (Again ask me how I know) Learning through experience is still learning LOL.
Twille
Oct 8, 2012
63
Hunter 38 Henderson, nc
Mega ditties on the panel. Just makes sense for 30 bucks and 45 minutes of time to be able to read stuff.
