New 150% RF Genoa, love it, but...
Mar 30, 2013
700
Last week all the pieces finally came together and My boat is now sporting a brand spanking new CDi head sail furler and a 150 Genoa from a major, well known and respected "semi-custom" sail maker. I went with this particular sail maker in large part because due to my inexperience I wanted some assistance from the marina with getting all the right bits and pieces and getting the correct measurements for the new sail. I trust the marina's expertise in this area
Sailed with it last evening and it is a fantastic sail, very well made has a great shape, the CDI furler worked great and over all I am very happy with the sail with one exception.
I specified I wanted the Sunbrella UV cover on the STARBOARD side of the sail. It was installed on the port side.
Now in the grand scheme of things it isn't a big deal, It works just fine the way it is, I didn't even have to make any changes to my furling line set up (repurposed and modified from my jib downhaul set up).
Thing is, I paid a pretty good chunk of change for the sail and it isn't how I ordered it.
I'm 99% sure the error came from the sail maker and not the marina which actually placed the order.
Since I installed it and have used it I suspect I'm just going to live with it as is and not make a fuss but darn it, it just wasn't the way I wanted it.
Gunni
Mar 16, 2010
5,937
Don't think I have ever seen a UV strip applied to the starboard side of the Genoa. Congrats on your new sail, a 150 makes a great all-purpose headsail in the light wind conditions of summer.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
My OEM jib has the UV strip on the starboard side. it doesn't seem to me that it would be a big deal to wrap the furling line in the opposite direction around the drum on the furler.
Doug's right, it simply doesn't matter. If you're a "purist" then put your jib in the other furling extrusions slot. :)
New sails always feel great, because they DO make/let you sail better.
Nov 13, 2013
723
Catalina 34 Tacoma
So you want to furl your jib counterclockwise as opposed to clockwise like most boats? Why? If you have a good reason for wanting it that way I'd take it back. Otherwise, if it works fine and it's only a vanity issue, get over it and enjoy the new sail.
The thing nice about the 150 is you can always make it smaller.
Mar 30, 2013
700
Like I said, it isn't a big deal, it's just not how I ordered it and that is mildly annoying to me.
My 1st boat (Macgregor 26S) furled CCW and my brain kind of "took a set" to it I guess.
But it is a darn nice sail and very well made.
I also got the foam luff pad/strips to help with sail shape when partially furled.
Aug 3, 2012
2,542
Congratulations! I have purchased new headsails and CDI furlers for my last two boats, and it makes a huge difference. I love the crisp feel of new sails. The boat sails better, closer to the wind, and accelerates better. I sail reefed, and the headsail works fine reefed in 30, 50, or even 70 % configurations.
Enjoy your new sail!
5,906
Oday 322 East Chicago, IN
Sail maker can probably remove and reinstall the sunbrella on the other side of that is really what you want. But I imaging they did it like (most) boats are set up. If you have a reason for wanting it on the non-standard side, and you were clear about the instructions, ask them to redo the UV cover.
