Most of those on here frequently know of my set-up already. 100W flexible panel that I take on and off of my bimini. The Charge Controller is a Genasun GV-10.
My panel only sits on the bimini when I am cruising. I don't bother putting it up unless I am cruising and need sustained charging.
Still, when Saga is sitting there waiting to be used there is that tiny little light blinking 24/7 since the one end is hooked up into my batteries.
It would be a pain to disconnect the controller from the batteries when not in use.
Would it be a good idea to put a switch on one side of the wiring so I can shut off the power going to the controller when the panel isn't up and in use?
When the panel isn't up it is stored in the cabin, unplugged.
Any thoughts, suggestions, or ideas would be appreciated. I just hate the thought of using any power when the boat is not in use. I don't leave the electrical hooked up unless I am at my boat as well.
