Mounted recylced Raymarine C80 MFD in a used Navpod.
pateco
Aug 12, 2014
2,207
My boss gave me his old Raymarine C80 multi-function display along with a DSM300 depthsounder and transducer several months ago. Since then I have been collecting the additional parts and pieces needed to install it on the Stargazer. Today I started the work. and finally got it mounted.
Here is the Pedestal before Showing the space I had to work with
These are the Parts I collected. Ray Marine C80 with DSM300 from my boss after he upgraded his boat. Navpod purchased for $40 at the Dania Beach Marine flea market months ago. and some Edson Pedestal mount brackets from Smokey73 here on the SBO Classifieds. Thanks Smokey.
Navpod had been cut for a different MFD, but luckily the hole was smaller than what I needed so I just had to re-cut bigger.
Fitting the C80 into the recut faceplate.
Navpod mounting holes did not work with the Edson mount, so I had to drill and tap new holes.
Boring bigger hole for wiring
Finished Edson mount modification
Ready to take back to the Stargazer
pateco
Aug 12, 2014
2,207
Here's some more pictures of it mounted.
Now I have to find a good deal on at Raystar 125 GPS receiver, and wire the whole thing up.
Anyone have any good suggestions on how to route the wiring down into the pedestal and below to the cabin 1/4 berth area?
Likes: SailormanDan
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
You may be able to run the wires inside the 1" tube of the pedestal and straight out the bottom. Use a grommet and 4200 where the wires go in.
Nice install by the way.
Likes: SailormanDan
pateco
Aug 12, 2014
2,207
I wish that would work. It would make it pretty easy. However there are too many wires for the 1" tube plus they have big terminations on both ends.
