proper use of boom vang
Oct 17, 2011
221
Catalina 310 USA
The 310 is the first boat I had that has a boom vang and, to be honest, I never adjust it. Are there any basic rules to follow for proper adjusting or use?
Thanks,
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
Lots. @Jackdaw will jump in. I use downwind to keep wind from spilling. I also use for upwind trimming to flatten in heavy air
Nov 8, 2010
11,386
A boom vang works along side the mainsheet to set the boom's angle relative to the water. It has the advantage of pivoting at the mast, so unlike the sheet, the boom angle does not change as the mainsheet is let out. This controls the mainsail's twist; the shape of the sails leech.
There are some simple guidelines for its operation,
Off the wind, set the vang so the boom is level with the water. Now easing the sheet will not let the boom rise and spill air, keeping the sail efficient. Now it you ever feel like you might round up, spilling the vang will stop that. When we race downwind, we have a person on the vang at all times. We call it the 'ripcord'!
Up wind in moderate breeze, I recommend most sailors keep it loose, and fully control twist with the mainsheet (plus the traveler). Once the breeze picks up, set it snug to your best upwind sheet angle. That way, an ease of the mainsheet keeps the same twist but lets the sail angle off, easing the pressure in puffs. This is called 'vang sheeting'.
That's the basics. Its use gets more complex, but that requires a matching understanding of sail trim, and the desire to work the controls in close concert. Start there and lets talk later in the season!
Likes: Parsons
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
What I appreciate about the many Jackdaw posts I have read, including this one, is how clearly he explains things. Many of us on this board know how to trim sails, and I could have done that explanation in a page or two. Jackdaw laid this out in a couple paragraphs, including helpful examples. Thanks again for clarity!
Likes: Jackdaw
Dec 25, 2008
1,580
catalina 310 Elk River
One note here, I use to race my J22 and we Vang sheeted up wind as well. With more flexible rigs this is an effective tactic as this will cause the lower section of the mast to bend and help twist off the sail. With our rig the mast is too stiff to provide this benefit.
JamesG161
Feb 14, 2014
8,004
Hunter 430 Waveland, MS
For Main Furling ( in mast )...
Release your vang and add about 6" of main sheet play as you head into the wind.
This allows the wind to slightly tighten your sail so you don't have a twist in your leech, as you furl.
Jim...
PS: @Jackdaw Thank you! There is a bit more if you have a Hunter B&R Rig which prevents down wind boom sweeps to 60° maximum.
Kermit
Jul 31, 2010
5,722
I use mine to adjust the pressure on the boom so I can deploy and retrieve the bimini.
You think I'm kidding.
JamesG161
Feb 14, 2014
8,004
At first I did think that!
I think I got it...
BOOM CRANE!!
Nice idea. I will do just that to deploy our dingy!
Jim...
PS: Apply for patent now!
Kermit
Jul 31, 2010
5,722
Y'all are giving me waaaaay too much credit. To try to clarify what I meant, I normally keep the bang sorta tight because it seems to me it should be sorta tight. But the bimini hits the end of the boom while being deployed when it's that tight. So I release the vang which pushes the boom up out of the way. After deploying the bimini (by hand) I pull the vang sorta tight again. Because it seems like it should be sorta tight.
Isn't it refreshing to know I don't deserve as much credit as y'all think I do?
Nov 8, 2010
11,386
Thanks for saying that. While I totally enjoy posting, its nice when someone notices. I also noticed that the OP did as well and mentioned it. That's great too.
Oct 28, 2013
678
Hunter 20 Lake Monroe
Jackdaw,
Ever think of writing a book? At a minimum we could put all your educational post in one section of the forum and label it "Read this First!"
I know I have learned a lot from reading your post. Your explanation of flying a asymmetrical showed me how much more use they have tHan just downwind which has made me want one even more!
Thanks for all the great info!
Sam
Oct 3, 2011
835
Jackdaw, Thanks from me, I have also raced and never thought about the vang as CLEAR as you stated.
:clap:
RussC
Sep 11, 2015
1,732
Merit 22- Oregon lakes
"Watch your 90" will forever stick in my mind now,each time I tack. a simple statement a few months ago that made things work for me. Thanks Jackdaw! :thumbup::thumbup:
Likes: Jackdaw
pateco
Aug 12, 2014
2,207
A reminder, before cranking down on your vang to flatten your sail for a heavy air windward leg, make sure your topping lift has been loosened. Ask me how I know this. LOL
