Transmission fluid questions
Apr 29, 2016
9
Hunter 1978 cherubinight 37c Madisonville. La
I have the little Yanmar Y3 with a cone type transmission it is brand-new only 300 hours. I have had everybody and their brother come in on what should be used as lubricant for the transmission some people say automatic transmission fluid Otherside 30 weight I finally got my hands on a Yanmar owners manual it recommends 30 weight without All detergent next question also I've had people tell me that I understand I should run my transmission in reverse I've had other people tell me to leave it in forward I finally got a memo from the Yanmar company they tell me to leave it in neutral or otherwise transmission damage could occur does anyone have any advise for this newbie
Apr 29, 2016
9
When I speak of transmission selections I am talking about when under Sail
May 12, 2004
1,505
If you have the 3YM20, I have the same engine. Had it put in brand new 8 years ago. You are right about the tranny oil. 30W. The question about transmission selection while sailing is one that has been debated ad nauseum. Never, however, sail with it in the forward position. I always sail with it in reverse to keep the prop from spinning. I come to a complete stop before I shift into reverse after shutting down and a complete stop before I start up again and shift to forward . The problem occurs when staring up, again. Sometimes the shifter won't allow you to go back to neutral. Don't force it. I just start with it in reverse and then shift to forward. Yanmar came out with that directive a few years ago. I asked the mechanic who installed the engine and several other mechanics about that. They all seemed to agree that it probably came out as a CMA response from Yanmar because of, maybe, a suit against them for a faulty transmisson. Most likely someone forcing the tranny into neutral from reverse. None of them reported seeing any damage from sailing with it in reverse. Of course, these people make a living servicing engines and trannys. I have over 500 hours on mine and not a bit of trouble. I'm sure others will chime in, also. Check the archives here and other sites about this. Get a cooler full of your favorite beverage because you are going to be at your computer for a long time and may come out with no more info then you went in with.
Jan 4, 2006
7,870
When it comes to your engine, I think most people here agree .............. kick the know-it-alls to the curb and rely on the Yanmar manuals and advisories only.
Ensure your transmission is a Kanzaki and not something unusual.
998
Hunter 38 Whitehall MI
suggest you do a search of the archives. There is a Yanmar service bulletin posted there in which Yanmar states that if you have the Kansaki transmission leave it in neutral and DO NOT sail in foreword or reverse. You will damage the transmission.
Now if you have a boat with a Hurst transmission they recommend reverse.
There are extensive discussions on this subject
