I do samei change mine from time to time not sure about the hrs ....i use the suction pump but mine only holds .83 of a pint
http://c34.org/bbs/index.php/topic,5139.msg31528.html#msg31528What color would the old compare to the new?
Perkins 4.236 with the Borg Warner velvet drive. I found some literature aboard that says two or three quarts. Thanks for the link. Our Service Mgr. suggested every other oil change on the main engine we should do the tranny. ( I'm a little behind).http://c34.org/bbs/index.php/topic,5139.msg31528.html#msg31528
What engine and what transmission do you have?
That link comes from this one with even more discussion:
http://c34.org/bbs/index.php/topic,6417.msg41657.html#msg41657
usually it looked like the new oilWhat color would the old compare to the new?
All U Get
My Volvo Penta OEM oil cost $50/quartWhat color would the old compare to the new?
humm must went from ab- to O+ no more cholesterolDone, about three quarts of dark red out, 2.75 quarts back in. I'll run it over the weekend and check the level again. Looks bright red again.
All U Get
