Hot water heater bypass
Dec 5, 2015
121
Oday 272LE Louisville, KY
I have an O'Day 272LE with a Universal M12 diesel and a Sealand 6 gallon water heater. My boat has not been launched since I purchased it. I am currently replacing all of the engine hoses. I do not need the water heater at the current time and would like to bypass it. Do I simply need to create a hose loop on the two engine heater connections and then plug the two heater hoses?
Thanks!
MitchM
Jan 20, 2005
1,031
most of the water heaters which have engine antifreeze loops run the hot engine antifreeze through a stainless steel tube inside the water heater. check with Seaward to make sure this is the case for yours. the hot antifreeze from the engine, running through the stainless tube, then heats up the water in the water heater. so you can run the engine with zero water in the water heater, and do nothing to the engine hoses into and out of the water heater. even if the water heater body fails and leaks, the stainless loop for the engine hoses remains intact. if you s tart needing to top up engine antifreeze , make sure it's not leaking from inside the HW heater loop. then you will wish you had the bypass already installed so you can run your engine.
it's nice to have a way to bypass the hot water heater if you need to work on it. if you are replacing all hoses anyway, why not put in a bypass? usual the engine hoses are 1/2 inch hi temp , you can buy NPT hose barb brass fittings and rig your own bypass for about $8. (DON'T use plastic fittings , heat of the antifreeze will damage them.)
Feb 8, 2014
1,300
Columbia 36 Muskegon
I hate to take away functionality from something that is working, but sure if you really want to. Just a short loop from where the hoses go to and from the WH and you're all set. Won't affect the engine at all except you'll need less coolant.
Jan 4, 2006
7,815
You could install a couple of isolation valves at the engine in order to isolate the engine from the tank heat exchanger. These are the two yellow handled ball valves. They don't affect the engine (Yanmar 2GM20F) as the domestic hot water heating loop is just a by-pass off the engine cooling loop. My reason for installing these valves was to isolate the heat exchanger in the event of of a tube failure when we're in the middle of nowhere.
Be sure to check the flow in the Universal engine to ensure this set up will not affect the flow in YOUR engine.
Likes: whatfiero
