Hi all
I have recently experienced the demise of my batteries at the hands of an unruly charger. As a result I am planning an electrical upgrade that will replace the charger with a Sterling Ultra 30 Amp charger. I am also planning to modify the 1/Both/2/Off switch as per Maine's article at http://forums.sailboatowners.com/index.php?threads/1-both-2-off-switches-thoughts-musings.137615/
I am not an electrical or engine guy but have been doing my research and have attached a plan of what I want to do. I would be extremely grateful if the electric gurus would provide their feedback. Also, I have a couple of questions
1. The modifications to the 1/Both/2/Off switch require that I remove the jumper from the alternator to the starting motor and replace it with a larger wire connected to the positive terminal of the house battery bank. I spent a bit of time looking at the engine today and am not sure which wire I am removing. I have attached a couple of photos of the alternator and starter in the hope that someone will clarify this.
2. The Sterling manual (echoed by Maine) says that the charger case ground (DC) needs to be run to the negative bus at the DC Panel. Is it acceptable to run this ground wire to the ground on the engine. This is a more direct route in my boat. If this is acceptable can anyone tell me exactly where on the yanmar 2gm20f the grounding bus is located.
The boat is a 1997 Hunter 310 and I think most of the details are included on the drawing.
Many thanks
Tim
Many thanks
Tim
