What the h@ll causes this?
Jan 7, 2011
6,003
Oday 322 East Chicago, IN
My DSC, AIS, VHF radio (IComm I believe), starts making this strange noise all by itself. . If I key the mike it stops, or I can turn it off and turn it on and it stops.
Anyone know what causes it or what it means? Ruins the peace and quiet when it goes off.
Gene S
Nov 29, 2015
181
Delphia 37 Tacoma
I think I had that happen once. Might be some kind of emergency alert. I forgot what I did. Maybe turn it off and on.
Jan 7, 2011
6,003
Happens every time I am on the boat. Sometimes more than once.
Very annoying, but if it is some sort of alert or signal, I guess I would like to know what it means.
Thanks,
Feb 20, 2011
8,062
Have you checked online, at all, besides here? Do you know your model number, besides "IComm, I believe"?
Hunter Catalina 400 PORT JEFERSON, NY
I have a Standard Horizon 2150 and I get a beep to remind me that my GPS is off and it is not getting a position update. Update time is adjustable, see manual. Standard Horizon has told me that it is a LEGAL requirement and cannot be turned off. I also silence it by hitting up channel on the mike.
Alan Johnson C400
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
hummmm.....maybe George Lucas will know.......R2D2 maybe......that is weird
Jan 7, 2011
6,003
The video you posted does not show an ICOM VHF radio but rather a Lowrance Link 8. If this is your radio then here is a link to the manual:
https://www.lowrance.com/Root/Lowrance-Documents/US/Link-8_OM_EN_988-10254-001_w.pdf
Thanks Hello....read through it, and see a few references to alarms and alerts, but still not sure what the sound is....an alarm, an alert of some kind? I will try to see the screen on the device when it happens next time and see if there are any clues.
I will add the manual to the list I am building for the boat.
Likes: justsomeguy
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
There's a text warning on the display. It wants position data. Your GPS is either off or not connected to the radio.
AIS only works if it knows its position.
Apr 24, 2006
868
Aloha 32 Toronto, Lake Ontario
As someone mentioned earlier it's the alarm indicating lack of position data. Legal requirement - can't be turned off.
Jun 1, 2004
8,345
Yes.... Skipper is correct. The screen message is asking for GPS position info... if your device is connected to a network for the data, make sure the network has power. Go into the menu and select the gps source... most likely the gps/chartplotter. Neither the AIS function nor the DSC feature will work without GPS position data.
These types of VHF radios have many many features.. I have the Simrad version of your Lowrance Link 8. Needless to say, it behooves you to study the manual and experiment with the settings. In particular, the DSC (digital selective calling) has a bit of a learning curve in order to enjoy its benefits.
It is unusual for a boat owner not to have a "boat book" which includes all equipment manuals and maintenance records. Perhaps you just haven't stumbled across it yet... good luck on building a new one.... Take advantage fo Google Search whenever possible to find technical data.
May 24, 2004
7,228
CC 30 South Florida
"Legal Requirement" sounds like the NSA is not content with tracking your cell phone but now also wants to know where to find your boat if they needed to.
Aug 3, 2012
2,542
Alan Johnson C400
That seems sensible... The radio in question has "Please enter position" on the screen as the alert is sounding.
YVRguy
Jan 10, 2013
479
Hunter 34 Vancouver, BC
Further to Joe's point, your radio isn't getting the GPS info that it needs to operate AIS or DSC functions. Both of these things require a GPS fix to transmit the location of your boat to other boats (AIS) and/or potential rescuers (DSC). Either the built-in GPS isn't working or it has lost its connection to your chart plotter.
