main halyard
Sep 3, 2013
22
bennetau first 310 stockton
I own a '93 310 and am wondering if anybody has a solution to this pesky problem: The winch on the port side, where the main halyard is led, is offset. With a winch handle on it, you can only take a quarter turn or so before hitting the stanchion of the dodger. Takes a long time to crank it up with quarter turns. Any solutions out there?
pateco
Aug 12, 2014
2,207
Remove or relocate the Dodger hardware, or relocate the winch.
Nov 8, 2010
11,386
That's not a boat problem, that's a dodger problem. The PO who added it didn't think or obviously care about that. So:
Live with it.
Remove or replace the dodger.
Get an ELECTRIC winch upgrade.
I can tell you that having an electric halyard winch is the cat's ass.
Sep 3, 2013
22
Liking the electric winch idea. One more question - is it possible to re-thread the halyard at the top of the mast so it runs down to the starboard side, where there is plenty of room for old fashioned cranking?
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
It should be easy to reroute the halyard if you don't mind climbing the mast. Run a fish tape up the mast from the exit point you plan to use. Pull the existing halyard tail to the masthead, routeit over the sheave you intend to use, attach it to the fish tape and pull through.
This assumes that you have a spare jib halyard or spinnaker halyard to attach a bosun's chair. If not, plan B would require dropping the mast.
Gunni
Mar 16, 2010
5,937
Take a look at the line blocks at the foot of the mast, and your deck organizer - you may be able to bring the halyard to your other winch. And yes winch handles come in many sizes, as long as you have two-speed winch you should be able to hoist a mainsail with a short winch handle.
Really odd to have a main halyard to port. Even on a Beneteau. Only the French seem to do that. They like vive la differance. :)
Raising the main: in many cases, we haul the halyard up 95% of the way from the mast, have a crew tail in the cockpit or use a cleat or cam cleat on the mast to hold it if you're singlehanding, and then only do the last 5% from the cockpit winch.
Feb 8, 2014
1,300
Columbia 36 Muskegon
My halyard winches are on the mast, no problem swinging as long a handle as you want. In my experience, leading the halyards aft ain't all it's cracked up to be.
pateco
Aug 12, 2014
2,207
The halyards on my Hunter exit at the very base of the mast. Designed to be lead back through the deck organizers to the cabin top winches.
Everybody has a different take. I like it, 'cuz it allows me to do my double line reefing without leaving the cockpit.
YMMV :)
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
my s2 has the main halyard to port and the foresail to starboard...not sure which is correct but they work ....if you raise the boom before you hoist you can hand load the sail by pulling on the halyard then when at the top drop the boom and just winch it tight and lock it down no biggie if you have good (clean) sliding sail track slides....
Jun 1, 2004
8,238
Totally agree with this opinion... especially the main halyard. However, if you have crew, and the halyard's mast exit block is high enough... have them stand at the mast and "jump" the halyard while you tail it in the cockpit. On a 31 footer with lubricated track and slugs you should be able to get the sail 85% hoisted before needing the winch. You can get a lot more force jumping the halyard at the mast than the cockpit because there is much less friction on the line and you can use all your muscles to pull down on the halyard.
Nov 8, 2010
11,386
No real 'correct' side when it come to main and jib halyards. Only for spin, with MUST be on Starboard.
Another comment;
Halyard exits at the VERY base of the mast were popular only for a few years, (early mid 80s?) when lines aft started to become popular. Builders thought that people would just crank it up with a winch. They seemed to forget that jumping it at the mast is still the fastest way up if you want fast. Now 99% of new masts have traditional jump-able exits with base blocks making the turn aft.
Gunni
Mar 16, 2010
5,937
Way down here in the land of cotton....we call it "sweating the main" when we stand at the mast and hand hoist the 'mains'l'. There ain't no jumpin' going on! :D
Nov 8, 2010
11,386
On Kestrel our last two 'mast' team members have been petite and athletic ladies. When they 'jump' the halyards while races they truly jump.... jumping up and grabbing it, and letting their 115lbs to help pull it down. The faster the sail is a full hoist, the faster we get rolling. This happens 10-20 times a race.
Sep 3, 2013
22
Thanks- my crew is generally my 85 year old dad- very little jumping going on. Considering a climb up the mast.
