Outboard locking problem.
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
On my Tohatsu 6hp outboard: has a thumbscrew on the back to control friction on spinning the top. It says in the manual not to be used to lock the motor in place. It's not kidding, can't be done. Anyone been able to make it happen or are bungee cords or cables my only option?
Aug 15, 2012
301
Precision 21 Newburyport MA
Ward H
Nov 7, 2011
3,814
It's a liability thing. Someone locked their outboard straight. Then when they needed to turn it to avoid a collision it wouldn't turn. Of course it was Tohatsu's fault. Now you can only adjust the tension.
Sep 30, 2013
3,646
But they'll SELL you a plate to PERMANENTLY lock it straight? That doesn't add up.
And if you want to talk liability, how about calling the motor a "Sailpro", and marketing it to sailors, but making it inherently dangerous (potentially deadly!) to use on a sailboat? Ever had your motor turn itself 90 degrees sideways while motoring into really snotty seas? Behind your back of course, so you don't see it happening? It's inexcusable.
But in answer to your question, DAVA390, yes, bungees are your only option. Ropes/cables won't work very well, because they don't stretch when raising/lowering the motor.
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
Remove said thumb screw, go get longer bolt in stainless that is 1/4" longer. take drill bit smaller than bolt and with motor in correct position drill small divit inside hole for new bolt to seat in. Install new bolt with gob of grease to prevent corrosion, motor is now locked.
If the tensioner bolt pushes a shoe the drill may not be required or you may have to dril and tap thru it and then install the bolt.
301
Also, I saw somewhere where someone wiped most of the grease off of the shaft then glued sunbrella material to item 23 in the parts explosion to increase friction. I can't find the link for it but if you do enough searches you might fine it.
Jul 13, 2010
1,100
Without having this exploded view I thought that the bolt might be pulling on a clamp and added s s washers on the outside of the housing hoping T o increase the strength of the clamping. No luck with that, I will look at these other suggestions, thanks guys.
Ward H
Nov 7, 2011
3,814
I remember reading the same thing. Sounded like just a way to get more clamping power to hold it tighter. Do I also remember correctly that by applying to much clamping force you can damage the shaft before you lock it in place. Sounds familiar to me.
On my 4hp Tohatsu I remember the same thing JSG posted. It was a clamp around a shaft that couldn't be defeated. Even my 9.9 Yamaha can be tightened down but not locked. That's OK with me as I use it to steer in tight places. Only minor inconvenience is when I tilt it back out of the water and it tilts to one side or another while sailing. I have to lower it before I can straighten it.
I do have it set tight enough it never moves from whatever position I set it when under power. That works well enough for me.
Jul 13, 2010
1,100
Thanks Tom. Printed that, going in the boat book for a winter project. I'll use bungee cords for now.
