What is this trailer accessory for ?
JVB
Jan 26, 2006
270
Schock Wavelength 24 Lake Murray, SC
There is one of these 10" by 2.25" pipes on each side of my keelboat trailer. What can it be used for ? Nothing that came with the sailboat seems remotely related to these pipes.
Kermit
Jul 31, 2010
5,722
If it's toward the back of the trailer it could be part of the goal post system. I added square tubing to the trailer for my Hunter 23. Other than that I got nothing. Which is typical for me.
Mar 20, 2012
3,983
wouldnt the "goal" post have to be in about the location shown for a sailboat?.... if they were at the rear of the trailer, the beam of the boat would make them worthless before the bow was engaged properly on the trailer.
as shown in the photo, the posts should be functional holding the front in position while the stern could still be controlled with slight motor thrust....
Kermit
Jul 31, 2010
5,722
Crap, I don't know. I have my goal posts behind the wheels. They help a lot.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
No bolt holes to mount guide posts. Kind of strange. Pipe is welded to the bracket but the bracket is bolted to the trailer with other holes drilled in the trailer. Maybe an old PO mod for a ladder connection? A foot hold for adjusting the shrouds when on the trailer......dunno.
kito
Sep 13, 2012
2,011
Maybe the remnants of a PO designed mast raising system that is long gone?
Nov 30, 2015
1,343
Since there doesn't appear to be too many hook/holes/gaps, in the trailer frame, this might be a good spot for the big over deck, tie-down strap connection, provided there's one on the opposite side of the trailer. Otherwise I got nothing other than a step up to the fender when boat's in the water or a backup support for the swing keel to take the strain off the cable when transporting...sticking a pipe across the trailer frame?
Kermit
Jul 31, 2010
5,722
At this point he can use them for whatever he wants. I like the torpedo tube idea the best.
Apr 19, 2012
1,043
O'Day Daysailor 17 Nevis MN
It's difficult to see from the picture if the tube is in front of the wheels or behind them. If the tube is behind the wheels this would be the ideal position for goal posts. Considering that most sailboats extend past the back of the trailer and, although the back of the trailer isn't at the widest part of the boat, the goal posts are still only a few inches wider than the boat at that point. Many launch ramps don't have finger docks requiring you to motor onto the trailer. Having goal posts toward the back of the trailer makes it a lot easier to see where the trailer is and get the boat aligned. Once the boat is over the trailer wind and current can move the boat to the side. The winch and bow roller will keep the bow in place. The goal posts are what help keep the stern centered until the trailer is out of the water.
