Intake thru hull size
Mar 27, 2016
90
Hunter 36 Hingham
what size should the thru hull be to engine intake on catalina 30 with a universal m25xp engine?
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
Match it to the strainer fitting so the hose fits. On my boat it is all 1/2" but that can change. Just look at your hose.
Mar 27, 2016
90
Hunter 36 Hingham
The hose is 5/8 the thru hull is 1/2 inch . I have to replace the thru hull so I just want to make sure I'm putting the right one in .
Nov 7, 2012
678
I just put our motor it in a year ago so built it to match. Depending on the thru hull type or strainer you get the hose bib fittings on the can be changed out.
