This is my first go-round with the raw water pump leaking out the back. I follow the threads about them, and now I need to either replace or rebuild my B323 3YM20 pump- a Johnson. Are the bearings a machine-pressed fit, or are they are push-in or "hammer/dowel assisted"? I already started using some PB Blaster to soak into the nuts/bolts. Other than the usual Yanmar suppliers, has anyone come across a lesser-cost supplier?
While I'm on the stump, I thought I saved a thread about a solid-frame overhead bimini window. I searched for "bimini window" but the 4 results are not the one. Help?
