My Yanmar 2GM20F does not have any springs attached to the compression levers....should it?You need to reattach that spring to it.
Greg,My Yanmar 2GM20F does not have any springs attached to the compression levers....should it?
mine don't and i have not seen any that doMy Yanmar 2GM20F does not have any springs attached to the compression levers....should it?
IMO every diesel out to have it, as it's a godsend if you have inadvertently depleted the batteries, or the toy wiring of the older Cats. have neutered them.mine don't and i have not seen any that do
so you will know i was referring to yanmars not m25s...... yannies have compression releases but no springs only levers with detentsIMO every diesel out to have it, as it's a godsend if you have inadvertently depleted the batteries, or the toy wiring of the older Cats. have neutered them.
It saved our bacon once on our little 5411soon after we bought the '82 30 last year.
Pete
Very good advice.stu, when i first got the boat i had terrible trouble starting my M25. after all kinds of useless advice i bought an engine manual, sat down and read it, and have not had any starting trouble since. at least 20 seconds of glo plug - right there in the manual.
