I have a newly aquired 1982 Hunter 27 with a Yanmar 1GM the alternater is 35 amps I have 2 batteries with a switch 1/2/both/off . I just installed a stereo with an amp 50 watts/ channel - the amp manufactuer says it draws 15-20 amps normal use.
Anyone have experience with running a radio/stereo with a similar size motor and altenator to help me understand how much it will drain batteries or if running motor either underway or idle will keep the batteries in good charge state? I also have a 11in by 30in solar panel I leave hooked up.
