Best way to remove varnish and duct tape residue from fiberglass?
Nov 15, 2015
271
J J/30 Seward, AK
Hi there!
The previous owner of my boat left duct tape glee residue and stray varnish swipes on the deck after maintaining the wood in various places. What's the best way to remove these? This should really improve the aesthetics of this boat...
Thanks!
Aug 17, 2013
1,343
Pearson P30 202 Ottawa
for the duck tape I like googone
for the varnish try with a razor blade and acetone
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I had the same problem with my boat many years ago. Cleaning up the wood is easy: sand and refinish (I used Cetol). I tried a number of things on the adjacent fiberglass, none of which worked. In the end I matched the color of the deck with new white paint. Worked really well.
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
WD 40 is worth a try on the duct tape residue. Not sure about the varnish.
Jun 6, 2006
6,990
goof off is a great product for the duct tape. Varnish? well the good news is it appears to be in the sun and is a self correcting problem. It will eventually secumb to the UV in sunlight and flake off. The only thing I've found for rapid varnish removal is mechanical scraping and picking. Not possible on some of your situations. Sandpaper in a hard sanding block and lots of elbow grease.
Nov 15, 2015
271
J J/30 Seward, AK
WD-40 actually worked really well for the tape glue. What would we do with that stuff?!
Now just to wait until the varnish flakes off I guess. I see no way to scrape it off the no-slip deck coating.
Likes: Fred
Feb 8, 2014
1,300
Columbia 36 Muskegon
If that's regular varnish it will flake off pretty quickly. If it's Cetol, that could take a long time. That's why we use it. Careful scraping will take it off .
