I haven't found any place that can refill my onboard CNG tank (Texas Gulf coast). Lots of places to fill a truck fuel tank, but not the small propane-sized ones. Do you know of any place?
Scuba tank size is the standard for marine CNG tanks. Can't buy them new since all the services here are leased tanks (turn one in to get another).I stand corrected on steel tanks but did you see the size of the small one. what size tank are you using if I might ask.the company were I work for is changing over to cngand the tanks are as big as veh is wide. cng is safe with good practice but still not enough inferstucture.here in florida
Any flammable gas or liquid must be used with caution. I am much more leary of LPG than CNG. Lets look at the facts _ LPG is in common use because it is readily available, even at your local self serve station, not because it is safer as a whole. LPG is heavier than air. Lacking some forced ventilaton or a clear and open low point drain to the exterior of the boat will sink to the low point (may not be the bilge if there is a low point close to the leak). It then concentrates in that low point and if the leak is big enough, will spill over to the next low point. It doesn't take much of a spark to get the LPG ignited! Then Boom. Is it safe - sure if handled correctly just like CNG is safe is handled correctly. The thing that surprised me is how many boaters carry a small LPG "can" for the gas grill, a heater, or a camp stove inside their cabin. They have all the safeties for their LPG stove (separate low point vented compartment for the tank, auto shutoff valve, etc) yet keep a source of LPG inside the confines of a compartment that is, by design, sealed at all the low points. Anything that will keep the water out will also keep the LPG in. Not so with CNG. Very few boats are "watertight" above the waterline. Almost all have some air leakage at the companionway hatch or somewhere else. Unless the CNG leak is pretty big, it will rise and leave the boat, especially if you have a solar powered ventilator. It will vent the gas long before the mixture reaches a combustable limit, unless it is a very big leak.cng is good stuff not putting it down just dont want people with little education playing around as it is with high pressure.( so you have a regulator at tank and run to the stove ?) I am in the industry and we are tought to always expect te worst poss sinario that can happen. I am certified in cng tank inspection and installation in veh, and the rules are very stringent. but that comes from nafta, and dot. tanks must be marked cng dated and working pressure, just resently had a sailor blow up using lpg he could not smell the mertane they put in the gas,smells like rotten egg,s it went down to the bilge and poof he died. cng goes up lpg goes down, the problem with cng is pressure. and availabilty to find it. good luck and happy sailing
Checking again, the CNG numbers are probably a little different (I'm getting a little conflicting info) but as a minimum the burst pressure of a CNG tank is at least 2.4 times the rated pressure so we're talking 7200 psi for a 3000 psi rated tank. Again, a significant margin for safety. Again, any flammable gas or liquid in the hands of a fool is dangerous so caution and maintenance are the key elements in safety.By the way - I just looked up the hydro pressure requirements for scuba tanks and I think it is probably the same for CNG tanks. it is 5/3 the working pressure. So a 3000 psi tank would be hydro'd to 5000psi!!! This is not even the "burst pressure" but the pressure the test is conducted at so the burst pressure would be considerably higher. So as long as a tank is properly maintained and hydro'd then I would not be concerned too much about it rupturing on me! Lets take that out of the equation on safety.
Here is the link to the scuba tank hydro
www.pyramydair.com/.../scuba-tank-testing-hydrostatic-and-visual-inspe...
Feb 15, 2006 - A common hydrostatic test is to pressurize the scuba tank to 5/3 of its working pressure and to measure the flexing of the tank walls. Five-thirds of a 3,000 psi working pressure means that the tank will be pressurized to 5,000 psi.
Picture didn't come through. I used a PVC pipe with a screw on cap on the top and a glued on round cap on the bottom with several holes drilled in the bottom. Three cans will fit in the pvc holder and it straps to a rail.Here's a photo of a propane bottle holder for the rail I made up for just the reason Smokey says, plus I didn't want it hanging off the BBQ.
Perfect. I went back and edited to show the photo.Picture didn't come through. I used a PVC pipe with a screw on cap on the top and a glued on round cap on the bottom with several holes drilled in the bottom. Three cans will fit in the pvc holder and it straps to a rail.
