Screwy Designs: What were those guys thinking?
Nov 6, 2006
10,247
Laughing, old Jag XK-150 and some MG's here, but the worst was a Fiat 850 I had that had some Lucas electricals in it.. Now there was a combination that had NO CHANCE!
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
How about anything designed by AMC. National Lampoon must have hired an AMC designer for the Griswold's Family Truckster.............
Aug 2, 2009
651
Catalina 315 Muskegon
I second the the complaint on manufacturers who don't provide access to the underside of the stanchion bases. Of course, what they're doing is installing the stanchions before they join the deck and hull. Gee, thanks, Catalina and anyone else who does that. You really think those stanchions are going to last a lifetime?
Why oh why can't you install a decent stanchion base like my Grampian 26 had. If I bend a stanchion, the base is unaffected, and it's just a matter of jamming a new stanchion in the base, for little cost and effort.
Oh, and on the Lucas thing, my first car was a 1971 Fiat 850, which for some reason never gave me any trouble. Third car was a 1961 Triumph TR4, which was pretty much the definition of trouble.
capta
Jun 4, 2009
5,101
Yeah, we give the Brits a hard time about their cars, but I still have a thing for those old dry-sump Nortons, Triumphs and the exotic Vincents. A T100C still rests in my shed, ready to roll. And what little I know about DC wiring I learned struggling to keep the lights lit on an old TR5. Anyone seen one of those? (no googling).
Had a TR3B just before I bought my first big boat and it was a real tank. After that it was always pickups. At least I've never had a minivan.
Our Zodiac doubles as our Ferrari these days.
Gunni
Mar 16, 2010
5,937
Yes, the TRs were all body on frame. Saved my bacon when I swapped ends on the TR5 a couple of times and punched it into a road cut backwards; blowing the sheet metal akimbo. That I-6 was still running with my foot pinned to the firewall. Walked away and got myself a very reliable German Ford. Put about 200,000 kilometers on that Fraulein mustang - Bosch electrics in good order and no oil consumption.;)
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
I certainly have learned much the past few days on the genealogy of my Sprint 1000 windlass motor, not to mention having gained a new appreciation of the foibles of British autos, which of course are legendary! Now, I'm sure it's hopeless for the windlass and a total replacement is in my future. I have another screwy design. Yes, to the issue of stanchion through-bolts that are not accessible for maintenance of stanchion bedding. It's not all that much better even if you can expose them b/c there's very little room to swing even a small socket wrench if located behind cabinetry. It needs to be virtually glued to the hand to prevent dropping frequently.
But the most screwball thing on the Bavaria that tasks me often is the companion-way hatch boards (wash boards). A total joke. There is no way they could hold back a ton or more seawater boarding the cockpit, especially the upper of the two. Made of lexan, they slide down the tapered companion-way entrance in a shallow track (maybe 2-3 mm deep) made of plastic and simply screwed to the side of the companion-way (i.e., not molded in; no molded backing fwd of the boards). High water could easily enter under the bottom of the lower board and into the salon. If the boat turtled they would be nearly useless. For a boat with an EU (Germanisher Lloyd) Category "A" (high-seas) rating, I've been dumbfounded by the design--an obvious after thought. The whole thing is on my to-do list to rebuild/replace but as we rarely cruise far from shore or in anything higher than 6-8 ft seas, it has not been a priority. Has anyone seen something similar? What would be a secure way to fix this kind of problem?
197
Islander 32 mkll Comox Hrb.
My brother had a Tr5, rare in Canada, I think only 12 in the country. It looked like aTr4 but had an inline six with overdrive, went like a bullet!
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
I've had a 57 MG-A and a 74 B. Lucas...Prince of darkness..I've had several meetings with Lucas yrs ago re aerospace applications and they were tops. I started the meeting wrt paybacks for my MGs...kidding of course. Wish I still had them. Specially the '57A.. We all got a good laugh and met for beer aftwrward....
1,096
CS 30 Toronto
I used to park my Bonneville T100 on a hill 3 blocks from my home so it can start in the morning. Engineers never use their own products. That's why the Romans make the architect walk the bridge before anyone else does.
RoyS
Jun 3, 2012
1,742
Aligning motor to prop shaft the other day in my 1980 Hunter 33. Took five days. Scars still healing on my arms and hands. Did the designer think that a wall against the starboard side of the engine would never be in the way? Should of at least provided a mirror and a flashlight.
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
"Why do Brits drink their beer warm?"
"Because they have Lucus refrigerators!"
druid
Likes: Jalepeno
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Having lived through and raced a 59 Austin-Healey Sprite, restored a 58 Jag Mk I, and presently driving an 85 Camaro powered 87 XJ6, I can write without hesitation that the only explanation for English auto electrical systems was the "never say die" design philosophy. Every part on these cars were rebuildable with part numbers right down to the lockwasher. When was the last time you could find, buy and replace every part to a voltage regulator? Of course, unless you could train a squid to use a spanner, most of the parts were utterly inaccessible without pulling the engine . . . .
May 4, 2005
4,062
On the vertical motors. I crewed on a bene 461 a few weeks ago, that had electric winches!
-they were really nice!!! (a little slower than 2 guys, but still nice, and we got so we were almost as fast tacking).
I wonder if they suffer the same fate as windless motors? -owner said he had them for years and years, and loved them. (I forgot to ask about his house bank and amps used). -but I could see them on my boat as I get older. (he had 2 for jib sheets, and 1 on the cabin for halyards/outhaul, etc)
anyone have experience with electric winches? -these were plates that fit below the lewmar winches
Jan 4, 2006
7,815
What other screwy designs have others encountered?:solame:
It's pretty obvious that Lewmar has designed their windlass motors to fail (frequently) inside of anchor lockers. You do not want one of these sitting inside the locker on a hot summers day while covered with salt water.
Hunter managed to design their locker such that the motor is not situated inside the locker and remains below and bone dry in the forward berth.
Jul 27, 2011
5,203
Thanks for the insight, RJ. Clearly, a vertical windlass with the motor hanging in the drainage below the gypsy head is a poor design. The big question mark is why Bavaria Yachtbau did not design an anchor locker that protected the motor, as you show for the Hunter, with factory installation of a windlass model having the motor mounted at rt angle to the gearbox, etc. All of these "budget" production models, the BAV38E included, seem to be a mosaic of often very strong, but also very weak, features. Having the "whole enchilada" with everything top quality would be 2x (or more) the sail-away cost, no doubt.
Jan 4, 2006
7,815
Don't know WHY they (all of them) can't look around and get it all together. I don't think these ideas are so much a matter of cost as just sitting down and putting some thought into what they're doing.
Nov 8, 2010
11,386
We have an electric Lewmar halyard winch on Kestrel and love it. Bought the boat new; 8 years on and no water ingress or even likelihood AFAICT. The motor is a horizontal job via a 90 degree turn. Nice design.
Jun 1, 2004
8,346
I'm not sure you can make such a blanket statement about Catalina sailboats. None of the Catalinas I have been on had inaccessible stanchion bases. I have seen many smaller boats that have NO stanchions....especially racing rigged sport boats.
I have never been on a C28, though.
Nov 22, 2011
1,303
Ericson 26-2 San Pedro, CA
Vertical windlass motor failures are many and common. And those motors are Lucas Electric. Just saying. Until water stops flowing downward you should consider replacing your windlass with a horizontal windlass that puts the motor in a sealed compartment behind the windlass gear. It is just a better design, and you should have room for it in your anchor locker.
I just tossed my 13 year old Simpson-Lawrence (Lewmar) into the metal recycling bin over at the landfill - for want of a proprietary $600 British DC motor. The drive gears were perfect, but when the windlass housing corroded and leaked it took the electric motor.
Is this true of all of the vertical models or just certain brands?
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
310 Access to stanchions is a real bear as well.
