Rule of Thumb: Yanmars (especially older ones) are a PAIN to bleed! Took the mechanic over 2 hrs to bleed my 2QM20 after I gave up. I suspect sitting for a while got the air in all one place and it finally bled out.
And the decompression lever is used so you can crank (and crank, and crank!) the engine when you're bleeding it.
druid
druid
