Hi all,
thank you in advance for any suggestions made regarding this problem.
My boat is on hardstanding, I have to lift my mast to install a new step, however, I have 3 seized open type bottle screws on the shrouds of my Beneteau 361. Having soaked every day for a week with WD40 and applied some gentle heat they still won't move. I have one last thing to try suggested on another site of "tapping" the bottle with two hammers, but don't hold out much hope. I noted that the bottom part of the screws are moving and in the event that the tapping did not work my plan was to cut the bottle off carefully with an angle grinder, keeping the fittings ( as there is nothing wrong with the cable etc,. ) and just replace the bottle. You may feel it would just be simpler and not much more expensive to measure all 3 ( or the 4th as well ) and have new shrouds made so they could be fitted whilst the mast was lifted? The plan is not to totally remove the mast to remove the old and install the new step. Any suggestions greatly appreciated.
