What are these?
Mar 28, 2015
184
Macgregor 25 Cherry Creek
On the bow of my boat there are two what look like hooks hanging down from the rails. I would really like to know what they are so I can either use them or remove them. My guess is they are something that I should be using. Thanks in advance for the continuing education.
May 1, 2011
5,567
Pearson 37 Lusby MD
I think they're used to hold older style anchors. I have a pair of 'em on my bow, too.
Apr 13, 2007
142
Catalina 27 TR Lorain, Ohio
Those are to mount a danforth anchor. I had those on my Catalina 22 with a Danforth that would have been appropriate for a 40 footer. The previous owner had been given the anchor. I had the right size already and swapped it out and took off the hooks. I still have the anchor in the garage because my C27 came with the right size and the one in the garage won't fit in the anchor locker of the C27.
Mar 28, 2015
184
The boat came with quite a big anchor and I believe it is the kind that would then fit in those holders. But I'm pretty sure it is too big not only for the boat but for the type of sailing we do (reservoirs, lakes, etc., not much big water out here in Colorado). Hey, maybe since I like to work with wood I can build a welcome sign and hang it from those points.
As always, thanks for the education!
Beneteau 323 Annapolis MD
[QUOTE...That's where you hang the mutineers.... [/QUOTE]
....BY THE THUMBS. I could have used them in the BVIs last month.
-na -NA Anywhere USA
I bought a set of hangers like that to hold the Danforth to keep it out of the cabin since my boat did not have an anchor well. Jackdaw hit it on the head not only with a spinnaker but also genoas as well as jibs. Think of it this way. If the sail was down and hung over the bow and up it went, rip rip rip and the is rip in peace with the wallet. I use to stick big sponges on the anchor to help prevent that but not really.
hey Greengas... I took a suggestion from Somner (also on this forum) and hose clamped PVC pipe to my bow pulpit and hung my anchors in those.... worked great. See pics. I used PVC pipe that had an I.D. that just perfectly allowed a 22 oz coke bottle to fit in the bottom. I then cut the top off of the coke bottle and slid it into the PVC pipe (first poke holes in the bottom of the bottle. I could then shove 5' of anchor chain into the PVC pipe and the coke bottle kept it from falling out the bottom. I kept 150' of nylon anchor rode on an electric spool.
Nov 8, 2010
11,386
If you have a small boat without an anchor locker, my suggestion is to keep the anchor, chain, and rope rode in a tough fabric bag and store it below, low, in an easily accessed place. Pack it so the tail end is out, then the rode, chain, then anchor follow.
This way it stores out of the way, will not foul your sail, keeps your bow pretty, and can be deployed very quickly.
Mar 28, 2015
184
That looks interesting. I like the thought of keeping the bow clear, but also like not having to drag the anchor out through the cabin, around the mast, etc. Also, loved the picture of the inside of the cabin. Do you happen to have one of the other side? I love seeing how people arrange their "stuff".
Mar 28, 2015
184
I like the nice clean look. i am putting in new wood for both back areas and i am searching for ideas on how to organize things. thanks again
Thanks
I put that bulkhead in using exterior grade siding plywood. The cut out box I purchased and I can tell you it was a big improvement. I kept my charts and hand-held gps in there all the time.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Further to Jackdaw's recommendation, you could also use a bucket. I have found someone else's recommendation of a rubber feed bucket (got mine at Tractor Supply) to be the most robust so far. The other plastic buckets I've tried are very good at cracking unexpectedly. I keep the ground tackle in the bucket in the cockpit lazarette, and set anchor from the cockpit, then move forward and cleat off at the bow. I have the end of the nylon warp clipped to the bail of the bucket, which can then be clipped to my bow pulpit, so I don't accidentally lose the bitter end. Then, the rest of the warp is loosely coiled in the bucket, so that it runs out easily without tangling. The chain and then anchor lay on top of the warp in the bucket. This setup works well for my Lewmar Claw, which I am retiring in favor of a Manson Supreme. It would NOT work for a Danforth, Danforth cheap copy (that probably won't set), or an assembled Fortress. That design with the long shaft and the bars that stick out at the end of the flukes is difficult to store unless you have a deck anchor locker designed for a Danforth style. But many other plow-like "next generation" anchors like Mantus, Rocna, Spade, Manson Supreme fit nicely in the bucket, and set easily and quickly. Hanging the anchor off the pulpit, or even an anchor roller, is generally not a good idea in a small boat. Weight at the ends = hobby horsing. Bigger boats, not so much of an issue.
May 4, 2005
4,062
I always want to be able to deploy an anchor fast....
Like when the dingy line wraps around the prop waiting for the bridge to open...
-ymmv
Nov 8, 2010
11,386
Yes. But think about this.
At least 1/2 of the time you want an emergency anchor deployment, it would be better if it went off the transom. Like in your example. Instead of running forward to the bow while the boat moves forward (and then swings around!), just drop it off the back and secure it as soon as possible. Having it easily accessible and deploy-able from either side could save the day.
What Jackdaw said + stern anchors are also great as a lunch hook. You pull into a cove, drop the hook off the back... eat your sandwich .... pull up and go... Greengas! I see you have a stern rail. Think about hanging a simple danforth style anchor in a PVC pipe holder off of the stern in addition to whatever you decide to do for the bow.
