Electrical Question
Mar 28, 2015
184
Macgregor 25 Cherry Creek
Hi
I have a Macgregor 25 with what I think is a unique battery set up put in by a previous owner. There is a single battery holder under a seat in the cabin. The wires from that battery lead to a battery selector knob designed for two batteries. A second set of cables lead from that selector knob to a spot under the seating in the cockpit where there are two battery terminals. That's it. My thinking is that the second battery terminals was used for the wire from a trolling motor to come through a hole in the transom (well above the water line, near the motor mount and covered by a clamshell). Once they were on the terminals, the selector knob would be turned to indicate both batteries and then the power would flow from the single battery. At least this was my original thinking. But now, I'm not so sure. If the battery selector knob is set on both then it is expecting an input from a second battery, not running power out to the lines. The terminals are full size, the type that takes a larger wing nut.
My plan is to run 8 gauge wire from the terminals to the hole in the transom where I have a quick connect ready so I can just plug in the trolling motor and go (and I have a 50amp in line fuse already in the positive line since it was the size recommended by the trolling motor maker).
So, is my plan good? Where is it lacking? How can it be better? I want to make sure of what I'm doing before I start running electrical stuff.
As always, looking forward to my continuing education.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
The switch doesn't care if the power is coming in or going out, so it should work as you describe. Running a trolling motor off the house battery will rapidly deplete it, however. An alternative would be the Torqeedo outboard. Much more power than a trolling motor, water proof, and the lithium ion battery is part of the outboard. You would still need a charging source for the Torqeedo, and they are expensive, however.
Mar 28, 2015
184
I looked into the Torqueedo and I really like it, but, the price for now is a show stopper. Last season I used my trolling motor, ok it did not move the boat very fast, but it got it where it was going and the group 27 batter never got below 80 percent. My goal is to get a gas motor this year if I can find a good used one. But as a start, the trolling motor was my best option. And, glad to know my plan was right as far as the batteries are concerned.
My education continues.
Beneteau 323 Annapolis MD
I'm picturing there was a 2nd battery back for the motor, but the house could be switched on if needed? Same could reverse, to feed motor batt to house?
