We do not live in California where the boat is slipped. I want to leave a charger on the battery bank so we can leave the refer on and assure there is 12v to the bilge if necessary. Plus I am not sure how long the repair of the inverter will take and we use the boat every couple of weeks and would like to continue using the lights, fans, etcc while we are there in the slip. I purchased a dedicated smart charger that will remain on the boat attached to the shore power. It varies fron 0 to 30 amps depending on the state and need of the bank. It will be disconnected when we sail and reconnected on return to the slip.
Now I would like to get to the original question. I have 2 sides to the system. The motor has a single 27 12v for the starter, and the house has 4. 6v with 2 on each side of the boat wired in series, and each side joined in parallel to form one large 12v bank. They are all AGM batteries, and they are interconnected with a combiner. Originally I thought it would be best to connect the charger to the single 12v but was not sure it would work with the combiner to keep the house side topped off. It sounds like everyone is in agreement that the combiner will work under theses circumstances. Johns suggestion to connect the charger to the house bank since it is the most $$$. Is probably sound. Stu backs it up but now the question is how to connect the 12v charger to the bank made up of 6 v batteries. As mentioned earlier there are 2 sets of 2 on opposite sides of the boat. If I connect the charger to the bank on the starboard side with the pos of the charger to pos of bat 1 and neg of charger to neg of bat 2 , will it charge that side as well as the port 6v bank and the starter side through the combiner?
