Has any Hunter 260 Owners seen this on their boat?
Aug 12, 2013
8
Hunter 260 Key Largo
I purchased a hunter 260 a couple of years ago and i found this hot dipped galvanized pole about 30" long. On one end it has two loops welded in. At the other end it has a coupling with a chain and a pin attached by a chain similar to the chain by the rudder.
I uploaded a file to give you a picture if my description fails to describe accurately the part.
Jan 4, 2016
4
Hunter 376 Marina Del Rey
Not an expert on the 260, but it looks similar to what I have on my 276 for me emergency tiller...
Nick
Dec 8, 2015
33
x 1 x
Agree with Rob... I have the similar emergency tiller adapter but slightly shorter for my H28.
Kermit
Jul 31, 2010
5,722
It is your emergency tiller. I highly recommend you test it before you need it. Those itty bitty fittings can get dirty or rusty and become difficult to use. I'm glad I tried mine. You'll understand about the itty bitty fittings when you use it.
Kermit et al. Is that something that was new with the 260? I don't have one on my H26.
Kermit
Jul 31, 2010
5,722
Because of the wheel. No wheel no need for emergency tiller.
May 24, 2004
7,237
CC 30 South Florida
That is correct. When a wheel steering system breaks down you need to have an emergency tiller as repairs can take time and parts but a tiller can be easily patched up in an emergency. Have had both faults happen to me and it is amazing what a couple of screws and duct tape do for a wooden tiller.
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
I have one in my H335. Very hard to steer with. On a BVI trip years ago we had to use one on a Beneteau 473. It took two of us to steer with it. Fortunately it wasn't to far to a mooring field where we picked up a ball.
Apr 11, 2014
97
Hunter 260 Lake Lanier
Good point on testing it prior to needing it Kermit. Need to do that on mine since I'm out getting her ready.
-na -NA Anywhere USA
When using the supplied emergency tiller for the 260, please remember that due to the shortness of the tiller handle, go slow when under power. In a sense it is like backing up under full power with the engine. If sailing, go slow mode or reduced speed and make long turns not quick abrasive turns with the emergency tiller.
