it really all depends on your amp usage and how much abuse the batteries get during their life...
with moderate usage, the 4 6v batteries may be the best option for longevity, but if you are going to install 4 batteries, the T1275's will give many more amp hrs, and if you have high amp use, the 1275's would be the best...
because, when using 6v batts in series to make 12v, you are increasing the voltage but the amps remain the same as if it were only 1 battery (in a sense it IS only 1 single 12v battery that you constructed with wires, by hooking the correct number of cells together. each battery cell contains approx 2.2volts)... so it takes 4 6v batteries wired in series (which equals 2 12v batteries to get any gain in available amps... each time you add another set of the)
but with the 12v batts where they are
already 12v, when you hook them together it adds the amps of one battery to the amps of the other battery, and so on with each battery added...
according to my calculations, at a 20hr rate the 4 1275 batts will give you 600amps
whereas the 4 105 batts will give 450amps... this is as advertised by Trojan.
if the amp hrs of all batteries were the same, no matter the voltage, it would take 4 6v batteries to equal the amps of 2 12v batts...
to more accurately answer your question as to which would be the best for you, we would need to know how many amps you draw, and how fast you draw them, and your charging habits you use to make sure the batts are always recharged in a timely manner.... and not so much what you
think these are, but what they
actually are, which is most often very different
