After much debate (and kicking myself for throwing my budget to the wind), I'm going to get Self Tailing winches for my 82 C-22. I came to this conclusion for two reasons; first, I can loose the cam cleats... but more importantly, I tried putting a few turns of my 3/8" headsail sheet around my small Andersen 10 winches (same same as the stock ARCO 6) and the small drum diameter just does not play well with any line size bigger than 5/16 or 8mm. So the Andersen 10's are going on the cabin top as halyard winches and I'll get Self Tailers for the primaries.
I was about to part with a large chunk of change on a pair of Andersen ST 12's, when I noticed that the ST 18's are only $45 more each than the 12's. What I need help/advice with is if the extra cost is worth what I will gain. I've listed the major stats below for comparison... basically the drum diameter is the same between the two, but the ST 18 is a bit taller, has a slightly larger base diameter, but the real kicker is the power ratio... basically double what the ST 12's power is.
I'm mostly concerned with the 18 being too large for the space it has to sit on the coaming. I found that one of my stainless steel bowls from IKEA has exactly the same base diameter, 4.75", so I traced out the footprint in pencil on the coaming... it just barley fits in the 'lines'. The ST 12 has a base diameter that is just .25 inch less, so it has a little more buffer. I know 'by the numbers' the ST 18 is a better winch, but I'm wondering if will just cross the line of being 'too big'. BTW, all the nonskid is sanded off of my coamings. I'll be putting on new non-skid in nice patterns around my hardware after everything is test installed.
Pics with stats on each winch below;
