D
Deleted member 117556
Several months ago I posted a question about solar vs a generator and got plenty of opinions which is what I asked for. Decided to go the solar route but have some self-inflicted constraints such as: (1) no davits and no plans to add them and (2) have a bimini but only open it when it is raining.
This makes it difficult to dedicate the space for a large bank of panels to keep my 290AH bank of batteries full on my relatively small 31 foot boat. After much research i decided to go for maximum efficiency and install a "pointable" panel to get max amperage with the minimum size panel. The pole mount off the stern was very easy to install and it clears the bimini (which was not an accident, it took several mock-ups with cardboard to determine the minimum pole length). Also installed an MPPT controller and battery monitor. The early results have been stellar. The main power draw is refrigeration and I first double insulated the icebox, replaced the Adler Barbour compressor & evaporator with a brand new more efficient unit. Now the batteries are down about 7-8% overnight and are back to 100% by early-mid afternoon if I do not rotate the panel and before noon if I do. When rotating the panel I can double the output. See the attached pictures of the amperage. These were taken within 2 minutes of each other at 9 am this morning with the only difference being I rotated and tilted the panel to face the sun. Input from the panel and output to the batteries more than doubled.
Am writing this just to give information to others because the amount of information on single, pointable, pole mounted panels is very limited compared to the banks of panels mounted to biminis, davits and even dodgers. The panel I purchased is a Sunpower 120 watt and it is supposed to be very efficient (most efficient on the market they said) according to the company I bought it from. They said to expect 5.5 amps from the panel and the MPPT controller would then deliver 7.5 amps to the batteries. See the pictures here it has already exceeded that. If anyone wants to know where purchased or anything else let me know and I will be glad to help. So far, this looks like a great solution for my specific needs but of course is not for everyone.
bob
bob
