I think the confusion between gybing to the inside or to the outside of the forestay lies in where the head of the sail is attached.
With my masthead rig, before I had a block mounted to the spinnaker crane, I used a 2nd genoa halyard to hoist my old sym spinnaker (I know, not the best way to do it). I didn't have a pole so I attached the tack to the forestay on a carabineer (which functioned similar to the ATN Tacker) with a downhaul for height adjustment. Because the head of the spinnaker was inside the forestay, naturally, I could only gybe to the inside, like a genoa, otherwise the head would wrap on the forestay if I gybed by flying the clew to the outside.
If I were to set up exactly the same way, except with the head attached to a spinnaker halyard running through the block on the spin crane, then I would have to gybe to the outside to avoid wrapping the head on the forestay because the crane is mounted over the stay.
I'm guessing that most are using a crane over the forestay, especially if you have fractional rig. In that case, the clew has to fly to the outside in a gybe. I think it has nothing to do with the ATN Tacker, which should be able to rotate either direction, inside or outside. I haven't watched the video, but my guess is that by gybing with the clew to the inside, they are using a genoa halyard and the head has to rotate inside the stay to avoid a wrap.
If you are using a sprit, I don't see how you can avoid gybing to the outside. In this case, doesn't the head of the sail have to be outside the stay, just like the tack is? I suppose you could pull it off by passing the clew between the luff and the stay, but it would seem far easier to simply gybe to the outside.
