Hunter 33.5 Air Conditioner
Feb 1, 2010
210
Hunter 33.5 El Dorado Lake, Kansas
I'm in the process of buying a Hunter 33.5 1993 that doesn't have AC. I would like to now the best location to install one from current 33.5 owners.
Jul 7, 2004
8,496
Hunter 30T Cheney, KS
Hey Amos, good to see you here! We ran into each other at Perry Lake when I was buying my Hunter 30T last fall. I hope you get good responses on this. Kansas summers are brutal without a/c. FWIW, our system was mounted under the forward berth and it works well. The admiral doesn't mind the hum at night. You may have other options on the 33. Where are you going to slip her?
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
Amos Cape, I have the same boat. Same year also. We raised the nav-station and built a shelf underneath to support the 16,500 BTU unit. From this location I ran 3 vents. One to each cabin. Installation of the plumbing and electric is also pretty easy. Sorry I don't have pics handy at the moment but have posted them on here before.
Feb 1, 2010
210
I hope your new boat is working out for you. It look like a very nice one! We have AC in our current boat and can't live without it. We are planning on putting it on El Dorado lake.
Feb 1, 2010
210
I will have to look at that area. How much did you raise it?
Jeff
Sep 29, 2008
195
We raised it till it met the under side of the electric panel. About 6 inches. The shelf for the A/C unit is the same height as the port settee. This left space below for shoes and such. I found a picture of the finished installation.
210
That is very nice work Jeff. What kind of wood was used for the new area that you added. It looks to be a very good much.
Jeff
Sep 29, 2008
195
Mahogany plywood for the cabinet box and Teak for the trim. Then I used Lemon Oil for the finish.
Feb 1, 2010
210
Jeff what were the locations of your vents? Did you use 6" ducting or 4"?
Jeff
Sep 29, 2008
195
There are three 4" vents. One in each cabin. The plenum of my air conditioner allows for three connections. Since the aft cabin hanging locker shares a bulkhead with the A/C unit I ran two ducts thru it. The first vent feeds the main cabin and is visible in my picture. It's located just below my radios. The second duct run in the aft cabin locker comes out the back of the cabinet near the top feeding the aft berth. The third duct run is located behind the settee cushions and under the bottle storage area. Several 4" holes need to be cut. It continues thru the head sink cabinet and into the V-berth port cabinet. My cabinet has several shelves in it. I drilled 4" vertical holes thru them to allow the vent to exit the forward side of the cabinet near the top. It sure is handy that these cabinets are screwed together. With a little disassembly the drilling process is a bit easier.
Here in the mid-west my 16,500 BTU unit does a fairly good job. It gets rid of the humidity in the heat of the day and allows it to be some what comfortable down below. The thermostat climbs to the upper 80's. I did install exterior Sunbrella mesh hatch covers on the cabin roof to cut down on the solar gain. At night this unit will freeze you out. It'll take the boat down into the 60's without missing a beat.
Good Luck on your install. Hope you figure out what location works best for you.
Jul 7, 2004
8,496
Jeff, is your unit a heater as well? I'm not too familiar with marine HVAC but our "new" Hunter has a Cruisair heat pump system that delivers either from the same control panel. It really extends the 'live aboard' season.
Jeff
Sep 29, 2008
195
My unit has an electric heater. There is a 5000 BTU coil the provides heat whether I'm in the water or on the hard. This really comes in handy when I'm needing a boat fix mid-winter and want to spend the weekend on board. I haven't mentioned to this point the brand I used. Flagship Marine http://flagshipmarine.com/ They have an informative website. What I liked was their units do not use expensive circuit boards that sometimes fail. Mine has been running for 12 years and I've only had to replace one $30 component in that time frame. A/C units are a personal choice and I don't want to push one brand over another. Cruise Air is a great brand too! I have several friends that use and love them.
Jul 7, 2004
8,496
Being able to run the heat on the hard would be nice. I have to run a portable if I want to work onboard.
Jeff
Sep 29, 2008
195
You're very welcome. It's a lot more comfortable to work in the boat while it's cool out. This process will help ya learn a few things about your boat. Good Luck.
Pat
Jun 7, 2004
1,250
Amos, good to see you and your wife last evening at the Ninnescah Y.C. murder mystery....What a heck of an event...
It take's bored sailors and Thumper of course to pull off that level of mid-winter entertainment.....Patrick Coulter
Feb 1, 2010
210
That was a great event! But the best part was seeing all my sailing friends that we haven't see for awihle.
Feb 1, 2010
210
Jeff that was the best location for this boat for shore. I installed 4" pvc for the ducts. Installed four vents, two in the main area one in the v berth and the aft. Thanks for all your time.
Jeff
Sep 29, 2008
195
Amos, I'm happy this install went well for you. It looks GREAT!!! Glad you contacted me and I was happy to help a fellow sailor. I'll bet it's quite comfortable sleeping with the A/C.
