Tach - Alternator connection
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
Thanks Benny - I had not seen that type of alternator /tach connection shown in the video before.
May 24, 2004
7,228
CC 30 South Florida
If you look at the diagram below the video you may also get a tap from the Stator running a wire through the casing.
11,772
Is it possible to hook up a tach to this alternator?
That looks like an older Mitsubishi 35A externally regulated alt. The terminals are generally:
E= Neg/Ground (for the brush)
F= Field = F (other brush lead)
N = Stator Tap / AC Pulse / Tach
A = 12V+ / B+
B = B+ to large battery cable
Unlabeled Stud = Case Ground
